Trevor, even if you swap to a different set of cams, do your car a favor and degree them. My DR street cams were anywhere from 1.5-8* off. You'll more than likely have to pull the motor, but you can probably do that in your sleep anyway.
Not sure if I can say it any clearer, aftermarket cams MUST be degreed. We are the only platform that seems to regularly just drop them in and hope for the best. I know I'm not Chris, Ray or Matt, but I have seen the difference first hand on cams that are considered to be the best for quality on the forums. The car felt noticeably different as well. After degreeing, the before felt like it was fighting itself. Boost took longer to build and tq dropped off faster as well. Unfortunately I can't find the logs anymore to compare the VD, but I'll keep looking.
Edit: found an old log. Started a new thread to show comparison.
