Page 1 of 22 12311 ... LastLast
Results 1 to 10 of 211
Thread: BC 280's have issues and Ray Rocks!
    I AM IMPORT POWER
    Driving Vicki Crazy
    Long read but worth it.
    So as some may know I am working on Courtney's car. Had to replace all the old braided SS lines as they were all leaking like a sieve everywhere. Old lines just not E85 compatible.
    So got that all done and also replaced the fuel filter element that was paper with a stainless steel element, replaced the old PTE 1000s injectors with new Deatschwerks 1000s since they would be full of disintegrated fuel hose.
    Found NGK copper 9's were installed which are way to cold for a street only car so I installed a set of the Champion race plugs.
    His AEM WB sensor was dead so I replaced that with a new one. And configured the AEM for the new battery off set table for the DWs.
    First startup an it seems to run not as smooth as I would like but it does have BC 280/280 cams so maybe that is why. I try to drive it a little to see where we are at with the new injectors. It does NOT want to accel smoothly, and low rpm lo load low MPH drive-ability is horrid. Missing, sputtering, no power. I obviously am not going to try loading it up and high rpm with it running like that. So back into the shop.
    Feeling like it's got a cylinder out I start testing. Since it is AEM I can turn off injectors. Turning off one at a time cylinders 1, 3, or 5 the car will chug and die. 2, 4, or 6 no change at all. They are not contributing. I can even unp;lug the rear injector harness. No change.
    I could pull plug wires for 2/4/6 off the coil pack, no change.
    Ok, for 2 days I tear the car apart and put it back together trying to find out why the rear 3 cylinders are almost dead at idle, and cruising. Very rough, low power trying to cruise at slow speeds at low RPM.
    With plenum off I can see the injectors firing, Plugs on the ends of the wires to test the entire ing system and the plugs are igniting.
    Swapped out injectors twice, PTU, Coil pack, plug wires, plugs, Traced all the wires in the ign and fuel inj system plug to plug and to the AEM and found no breaks. The plenum has been off no lie about 12 times. Even tried my AEM with no change, and his AEM in my car which ran fine.
    Checked timing and found he had Fidanza cam gears and surprise...they had slipped like they always do. Rear exh was at +5 degrees instead of -3. Front exh at +3 instead of -3. You can tell where they used to be by the score marks the washers made as hey slipped. Thought I found it. Removed the cam gears and after finding true 0 cause they are mis marked making -1.5 true 0 I Pin/locked them down at +1 -3 as I always suggest and how I run them on my car. Now they can not move unless they sheer the bolts, which they won't.
    Still, no change. WTF?
    At this point I am pulling my hair out. Last night Vicki says, "Ask Ray, he may have run into this issue." I have always said, I don't know everything, someone else always has an idea or direction you may not have pursued. And sometimes you just need to step back and get a new set of eyes on the issue. And at this point I have no other directions to go.
    So I asked Ray Pampena, Told him the whole scenario as I have written above. First thing he asked me straight up was "Does it have BC 280 cams?"
    I said, YES!. He said, take them out. Put stock TT cams in it.
    He has had this happen 3 out of the 3 times he has tried BC 280 cams in cars. Back bank, dead stumlinb missing at low RPM low load. Back bank just not contributing as it should. Every one fixed by putting in stock cams.
    So even though I just had the tbelt off to do the cam gear fix and had put it all back together (i thought I found the problem) Today I pulled is all back apart and swapped in a set of stock TT cams (V/D).
    Know What? Purrring like a kitten. In the AEM I can now turn off each injector one by one and each one is contributing and turning just one front bank of doesn't make it die. Every one is equally contributing.
    Ray says he has never figured out why the BC280s are doing this but every time stock cams have fixed it. My take is they are probably so far off that is makes the rear valve timing such that they don't contribute.
    I ran into BC issues in the past, A set of BC cams would be degreed using a degree wheel and all 4 were so far off from each other in a set it was as if they should all have different cam cards. BC always denied ANYTHING was wrong with their precious cams. We knew different. I used to sell them. I have taken them off our site. I refuse to sell a customer a problem. We are working on a solution.
    Thank you Ray! You rock. All of the parts, wiring checking, running in circles. All because shitty cams.
    -Chris
  2. The Following 7 Users Say Thank You to Ninja Performance For This Useful Post:
  3. #2
    there was a batch of bc 270's for the SR that also had this issue, thankfully i had no issues with my 264's but after reading up on them, i wont run BC cams again.
  4. #3
    Member
    Chilliwack BC
    Prior to pulling the BCs, did you get a chance to check the cylinder pressures after you had the gears dialed in?
  5. The Following User Says Thank You to Primus101 For This Useful Post:
  6. #4
    Forum User supporter
    Bounemouth, UK
    It sounded like the problem I had when 3SX accidently sent me two rear inlet cams which I fitted without knowing
    Took me months to figure out. Must have taken the plenum off 20 times
    Jeff
  7. #5
    i'm NEVER buying cams. thanks for the info.
  8. #6
    Sep 2011
    I'm thinking the cams have big over lap that's why it's hard to get it running on low RPM or idle and since we have very high gear ratio the car is always down low in rpms. I got to look in to the cam card sheet to see how much overlap they have. Now I Can't comment on cam timing difference though. I have yet to match the bc cams vs stock cams but i try to do it today. Trevor and saf are running same cams and they don't have the problem of rear bank not running right though as far as i could tell. I just Talked to Saf about his BC 280 cams and he said the car is powerless under 2500rpm but above that the car makes tons of power. This is a character of big cams. ruff idle is a down side on big cams. I guess the best is to time them right on both banks with cams timing gear and run higher compression to get rid of that no power down low problem? Saf is running 8:1 compression and Trevor running 9:1 compression. I'm now kind of concern about running these cams on street cars. I'm going to ask Trevor and see what his car is to drive on normal driving condition with higher compression ratio, but he has 6 speed so the car picks up speed easier. . I know he does have stock 74 camgears so I am sure his cams are not timed to the spec.
    edite: It seems he has the same problem, but not sure if he has fixed it yet with tune.
    AEM - Ignition Setup & Injector Advance - 3000GT/Stealth International Message Center
    I'm going to see if a better ECM (proefi 128) can fix this problem. It seems there is window where AEM can't keep up with the engine?
  9. The Following User Says Thank You to mehrshadvr4 For This Useful Post:
  10. #7
    I AM IMPORT POWER
    Driving Vicki Crazy
    Wow, and Trevor is running BC 280s. And looks like going back years on 3si others have BC issues. They have been junk since they came out and that is why we won't sell them. j
    -Chris
  11. #8
    I don't bite
    Southern IN
    When you degreed them, did you check more than just #1 and #4 cylinders? I bet they are way off cylinder to cylinder on the same cam/bank. (i.e. degree cam at TDC #5 also and compare to the adjustment needed when degreeing #1)
    Any regrind isn't going to be perfect, the info I read said to just shoot for the average but I bet the BCs are off a lot. My web cams front intake is of a few degrees cylinder to cylinder but I just split the difference.
    Edit: reread your post, if you "zeroed" based only on the known mistake of the cam gears and not actually degree the cam, there is no way of knowing where you actually have the cam set. It may be close, or you may be off a whole tooth... or more. Not really fair to blame the cam yet if that is the case...
  12. #9
    I AM IMPORT POWER
    Driving Vicki Crazy
    Yeah, I am NOT degreeing 4 cams in the engine, with the engine in the car. Not happening. LOL
    -Chris
  13. #10
    I'm magical... verified
    Andover, KS.
    Yeah, I guess I'm nuts for still running the BC 280's.
    Bad:
    - As was said I'm running stock 6G74 cam gears and from what I've heard the cams are most certainly offset by a couple degrees.
    - <3200 is relatively weak. Might have something to do with the GTX4202R with a 1.44 A/R T-Housing though. VD Dynojet shows 177 lbft @ 1500, 200 @ 1936, 250 @ 2864, & 300 @ 3142
    - At 1600-2400 rpm & in slight vacuum (4-8 in Hg) it's very stuttery/gurgley. Pretty sure it's a harmonic or a reversion overlap issue due to the cams.
    - Idle is a bear to tune. At 1k it only pulls about 8-9 inches of vacuum.
    Good
    - The rear bank is definitely doing good work.
    - Torque goes damn near vertical at 3500.
    - Even with the tuning difficulty idle is still consistent...the car never dies. Sounds great too:
    After the next track day I'm planning on going back to regrinds of some sort. I'm tired of the stuttering & popping during cruise. DR, Delta, WebCam...the most aggressive ones I can track down. At least then I'm sure peak lift will be in the right place without the need for degreeing.
    2011 CTS-V Coupe
