Confirmed: disabling the front o2 sensor and setting closed loop to operate off just the rear vastly improved the way the car runs. Definitely a swapped o2 jumper.
Easy fix!![]()
Easy fix!![]()
www.ClonedECU.com
Get Chromed!
1999 3000GT VR4
Glacier Pearl White
How To Contact Me:
eMail: brett_farnam@yahoo.com
US3S/3SGTO: 99 vr4
3SI: bfarnam
I don't get it..... And it is an honest question....
Please give me a call, or pm me. All my ECUs have a two year warranty from date of purchase.
The 91-93 Plug and Play Ecu should never need to be opened to turn jumpers but the option is there if you wanted to have both banks trim off just one O2 or to easily switch the banks.
Anyway please give me a call I would like to get some details about your car.
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
I'm having the same knocking and low Idle as well but I have one of Adam's Clone ECU's. I adjusted the target Idle up and that seemed to fix the low idle but the knock is still there. Just changed all my fluids too and my SB Stage 4FE clutch has less than 10k on it. O2's are new too. I can try to disable the secondary O2 as well and see if it helps. Ill report back after lunch.![]()
1991 VR4 - TD04-19THL, DR Stg3 heads, All forged lower end, Adj. Cam gears, Boost Exh. cutout, Walbro 341 HW'd, 720cc inj., AEM FPR, Hallman MBC,
Clone ECU and Chrome V2 - Tuning for 20-PSI on 91 Pump at the moment
If your O2s are cycling then you have a different issue.
Yep. Check for leaks.
