I did get some logging done last night but boy is it hard to find a road with a long enough stretch to top out the 3rd gear, in my area.
There are a few spots where I could easily go over 130 comfortably and safely but that's including going through first and second gears first.
With out compromising safety even further outside my comfort zone and cutting it close to the end of the road, I've barely managed to get my 3rd gear up to 6000RPM at which my speedometer was showing me a little over 120mph.
There is so much lag up until 2500rpms in every gear. If I floor it before that area there is just no power and once it reaches 2500 rpm it kick in like a mule. (Under normal driving it still kicks just not as hard)
Once I floor it and my turbos eventually spool up my boost spikes to 15psi at 2500rpm on my after market gauge and then comes down to the usual 9psi by 3500rpm.
I'm not sure what you mean by a 5 min log. I've got a few logs of my 3rd gear pull from 35,40 mph to 120mph and a few of me driving normally in the city and the freeway.
I'm not sure how to post logs on here: copy and paste from excel as text? Screen shot it and post it as a pic? Any other ways?
A pic of my stock ECU idle fully warmed up
https://sphotos-b.xx.fbcdn.net/hphot...82800261_n.jpg
A pic of my Chromed ECU idle fully warmed up
https://sphotos-a.xx.fbcdn.net/hphot...21241756_n.jpg
Here is a video of my clutch chatter/knocking at idle
http://www.youtube.com/watch?v=9ZExT...ature=youtu.be
Thank you guys for looking.
All I needed was a snapshot of evoscan when the problem is happening. I wouldn't beat on the car with something wrong like this.
log the o2 sensors, rpm, tps, isc counts, etc and just post a csv file as an attachment here. Just log it ideling for for a minute or so.
you're idle is very low with the chrome ecu
Looks like the front and rear o2 sensors are swapped on the jesters chip.
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
Makes me wish i have my extra ecu handy so we could meet up and do a quick hardware test.
Maybe Jester can swap you out for a new one?
