Page 430 of 892 FirstFirst ... 330380420428429430431432440480530 ... LastLast
Results 4,291 to 4,300 of 8916
  1. #4291
    Jan 2011
    az
    Think I made another costly mistake not knowing. Set the timing on my car months ago but it wouldn't fire but everything lined up perfect .. Figured I had the cas sensor wrong and I did . So I switched it 180 degrees. Car sounded like it wanted to fire . But got a loud as bafckfire instead . So I pulled the timing cover and stuff off and with the crank at tdc , nothing lined up . Even turned the motor over by hand 2:times to see if the gears would line . They are way the fuck off !! Man I'm so stoked .
  2. #4292
    Man vs 3/S verified
    Kingston, WA
    Went sideways
    Vids or die.
  3. #4293
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Went sideways
    Vids or Full of shit.
  4. #4294
    UGH, OK
    Maybe sideways vids by next week
  5. #4295
    94 3500gt vr2? verified
    NC
    Some work on the rear today. Megan springs, slotted rotors, ceramic pads, painted calipers.
    Always forget to pay attention with slotted rotors... but luckily this time I put them on the right side 1st try
    *Just noticed, I probably don't need that exhaust hanger any more
    Done
    Doesn't look like much of a drop yet
  6. #4296
    oct.2007...
    UGH, OK
    looks like fun!!
  7. #4297
    One fix at a time verified
    Kansas
    I renewed tags online and put it on storage insurance for awhile. It should give me motivation to send out a VCU core, build the SCE/Quaife 5-speed, and start swapping things over hopefully with some restoration work and paint but who knows how much time I'll have. I had other things on my mind with my grandpa going for quadruple bypass surgery tomorrow.
  8. #4298
    Sold my series 2 to be able to go flash!
  9. #4299
    tuned the flash on the 1050s a little bit more today. pretty close to stock afr and good fuel trims. When I run this tank out of fuel I'll swap in some e85.
  10. #4300
    Feb 2012
    Westbury, NY
    Installed a new chinese eonon doubledin radio with navigation, ipod, dvd, am/fm, usb, 3.5mm jack along with JL audio speakers. Retained the existing sub and amplifier. Say what you want to say about the quality of the asian products but there are a lot of mainstream products made in china and malaysia anyway, just different quality control.
    So far the unit has performed flawlessly. I wish the rca outputs were rated at a higher voltage but my 5-channel amplifier is more than capable of driving the system. Will see how it goes over time. I had a choice of paying $600-$900 for a more popular brand, or investing a couple of hundred to try something different.
