Page 188 of 355 FirstFirst ... 88138178186187188189190198238288 ... LastLast
Results 1,871 to 1,880 of 3547
  1. #1871
    You are running FWD rear springs on a AWD rear subframe?
    St.Louis
    Nope, running awd megan springs. They don't make fwd megan springs as far as im aware.
  3. #1873
    OK, I see, Right after my AWD conversion I put stock springs on the back and the drop was almost perfect. Any non adjustable lowering spring is going to be too low (unless you want to go hella-stupid).
  4. #1874
    i was running stock tt shocks/springs. it was still too low. at least after i put 285's on it.
  5. #1875
    I still had eibach on the front so it put my front and back at the same height. Looked perfect to me but I think I like mine a little lower than yours though.
    Edit: since mine was lowered in the front it might have brought the rear up a bit.
  6. #1876
    don't get me wrong, the rear actually looked decent. but with the front at stock height & the 285's rubbing on the rears...it was time for a change.
    with the d2's, the front is a tad lower and the rear a lot higher. i prefer ground clearance over stance.
  7. #1877
    JNS Engineering verified
    San Jose, CA
    Quote Originally Posted by Bloodlust182 View Post
    Can't comment on fwd to awd conversion but I can say that adjustable upper control arms might help to pull them in if you're willing to run some negative camber.
  8. #1878
    I don't bite
    Southern IN
    Almost unbroken...
  9. #1879
    Canaan NH
    Looking good FamilyMAN.
  10. #1880
    Jan 2011
    Looking real nice. Plug up those intakes and turbos though, leaving stuff like that open gives me the shits!
