Page 417 of 892 FirstFirst ... 317367407415416417418419427467517 ... LastLast
Results 4,161 to 4,170 of 8916
  1. #4161
    Jan 2011
    az
    Started on the engine wiring harness yesterday . Gonna finish the install today and also wire in the arc2.
  2. #4162
    Feb 2011
    Scottsbluff, NE
    Not my 3S per se. But still 3S related. Did the IC piping a while ago and did the VC/manifold last night. I love the way it looks. Now he just needs to get rid of all the red vacuum lines left over from the previous owners color scheme.
    1995 Dodge Stealth R/T Turbo
  3. #4163
    Pueblo, CO
    Just installed the wiring into my AEM EMS to my clutch for NLTS. Finally had a minute to get that done. Hopefully ill have some time Tues to take her for a spin and try it out. Just have to get the rev limiters and ign cut for the antilag setup right
  4. #4164
    JNS Engineering verified
    San Jose, CA
    Removed rear roll pin. Bought and assembled engine stand and got M12 x 1.75 x 70mm grade 8.8 bolts to mount it up. Removed bumper and positioned hoist for the pull.
  5. #4165
    Member
    Chilliwack BC
    Hey Jim, Have you done any max lift measurements for that hoist with the length of chain? You might want to choke up a bit, as the cylinder looks pretty extended as is-
    With a third strap on the trans to keep it level, you need to have approx. 26-27" lift (measured from bottom of bellhousing to top of upper belt covers) to clear the rad support.
  6. #4166
    San Jose, CA
    Quote Originally Posted by Primus101 View Post
    Thanks, I still need to go over that. I probably need to get a ratchet strap for the trans too.
  7. #4167
    Got any more pics of this car? That's a pretty cool green.
    Good eye, I don't think that will work ether. I had to set an engine back down once. That kind of sucked.
    Ratchet strap for the trans is a definite. What did the engine bar run you?
  9. #4169
    yeah I practically had the load leveler sitting on the plenum. I think that is the same one I used
  10. #4170
    San Jose, CA
    Thanks. The leveler is borrowed along with the hoist. Appreciate the comments as this will be my first ever pull Where do you guys hook up the trans strap and do you do it first thing or on the middle of the pull?
