Page 14 of 20 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 195
Thread: Now Another Problem.....
  1. #131
    OK, so I jumped pins 4 and 5 on the low fan relay, where the signal should connect and start the fan. Nothing. I checked the plug again, and only 1 pin had power to it still.
  2. #132
    Canaan NH
    There should be power to all but one of the pins on the relay but only if the relay is plugged in. If its out there should be power to two of them. Provided the fan can feed power to the gound pin when not grounded.
  3. #133
    Canaan NH
    Quote Originally Posted by GRSHOPR View Post
    That shouldnt work. If you ground pin 5 the fan should run though. At least it wont work if the harness at the radiator is wrong or the sensor isnt hot enough.
  4. #134
    OK, so now there's no power to pin 5. I did cut the two wires the weren't part of the plug, to see what that would do. Can't remember why now. But the oddest thing happened. When I turned off the car, and turned the key to the ON position without starting it, the fan turned for a few seconds....??
  5. #135
    I remembered why I cut those wires. I was testing them for power. One did have power. Should I assume that power line should be attached to the radiator plug??
  6. #136
    Canaan NH
    I would say it goes to pin 6 of the radiator but its hard to say. Where is the wire leading to ? If it goes to pin 3 of the high relay then yes it goes to pin 6 of the radiator.
  7. #137
    It's coming off the harness. Not sure where it's coming from. Unfortunately, it happens to be the same color as another wire in that bundle. I used the SWAG method to choose which was which.
  8. #138
    Canaan NH
    You could test this with a ohm meter and the relay removed. Hold one of the meters leads to the cut wire, the other put in pin 3 of the high relays socket. The relay must be remove to check. If you have continuity then its the right wire.
  9. #139
    Canaan NH
    Whats SWAG ?
  10. #140
    Scientific Wild Ass Guess. OK, so I was mistaken before. I misread the signs. Both pin 5's are being fed by a wire on the plug. It's red and black going in from the harness side, and blue and green (i think?? it's definitely not the blue and black wire, but I can't discern any yellow or green marks on it. I'm pretty flipping sure it's the green one though. green is more subtle and harder to see than yellow on these wires) coming out the radiator side. It stands to reason, then, if this is true, that up to both pins 5 is correctly wired.
    Edit: And you were right. There are 5 pins on the relays, but pin 2 is small, it's easy to miss.
