This might help you.
Straight ground.
OK, so we are looking at pins 3 and 6. Those are the two extra wires.
Ok. Both of those wires are used to provide ground from the sensors to the coils in the relays, this is your problem. On the high and low relays these are the pins you didnt measure power on.
Honestly, I'm fried from looking at so many diagrams. I'm confused by the fact that the wires from the thermo sensor don't correspond to what is in my bay in regards to their color, so I'm going to go through this step by step. Can you proof my thought process, to make sure I'm not going crazy??
Connector A-55 is the plug off the radiator. The two extra wires from the 6 pin plug were on one of the far sides of the plug, top and bottom of each other. That means they would have to be pins 1 and 4, or 3 and 6. The problem I have with that, is that per the diagram, pins 3 and 4 both power the fan. I checked the physical wires, and they do correspond. The light blue wire with yellow (pin 4) and the light blue wire with black (pin 3) do go to the fan motor, not the sensor. There are 2 black wires (grounds), on the radiator side of the plug, and only 1 on the harness side. In lieu of a black wire, there is a red-black wire. And that's as far as I've gotten. is that right?? Can you complete the puzzle?
Pin 4 powers/grounds the fan, pin 3 is to ground the coil in the same fans relay. This is the low relay, hence the resistor. The radiator side of things doesnt acually power anything, it supplys grounds. You should have 2 wires from the harness that will have 12v on them, these go to 3 and 6.
I only have 1 wire with power to it, and that is pin 2?
AHHHHH. We are making a grave assumption here, and I am wholly to blame. This radiator is a 1st gen, but there's no way it could be a 91, based on the wire colors. Let me figure out exactly what year it is.
Edit: It doesn't matter what year it is, all the wiring is the same. None of them show a straight red and straight green wire on the male side (radiator side) of plug A-55. I don't get it.
According to the schematic that is only possible if the coil in the low relay is bad, and the one with the power would go to pin 6 on the radiator. Pin 2 of the radiator should be empty.
