I wouldn't be to worried, I would be very surprised if you blow your engine from too much timing. It will likely run terrible before you actually start doing damage. However, running too much timing for a long period of time, even on a low horsepower engine isnt exactly very good for the life of the bearings. You need to remember that pretty much all the story's you hear about people knocking and destroying these engines were people that were boosting and running out of fuel or detonating.
Trevor has posted his timing maps and experience several times, especially with his 3.7 setup. I can attest to his conclusion that the 6g74 wants MUCH less timing advance than the 72s. When it gets new head gaskets soon, I will be leaning it out under boost (e85) and low single digit timing at peak tq.
