unless you start using a tool like virtual dyno I wouldn't keep throwing timing at it just because their is no detonation noise. Like Greg said earlier you can still be applying force to the engine at the wrong time and just beating up the bearings.
What I would do first is pickup a flash ecu where you can properly set the engine timing. This will also work for you when you want to go turbo.
