You need a stroker to keep up with us lowly TD04 cars.![]()
Parts are expensive on the 6G72 stroker. I was lucky to get a nice used Debonaire crank for $150 locally. It cost another $1600 to machine the counterweights down to 72 size, cut the rod and mains down, and balance the crank with Mallory. It cost another $800 for Ray's custom stroker pistons with rings, $185 for .220 wall Pampena race wrist pins, and I ended up buying another block from the original one I put the stroker in because copper o-rings didn't work out. Shipping it all to and back from Rays is expensive too. The only downside to it is if I screw up the motor I'm out another $1600 plus the cost of the crank($900 new) and any other damage if the crank is screwed up. I wouldn't be able to replace it very quickly because it's not chump change for me.
If you go with a 6G74 block, forged 74 rods, and forged 74 pistons if something happens to the crank you're only out $900 for a new crank plus the balancing cost unless you buy a used crank for much cheaper. Modifying the 74 to fit isn't that bad. To do it again I would have definitely gone this route. I also wish I could have afforded a billet crank too but that's another $4k blowing my budget away.
A built 3.0L with heads and cams would be a great option. Unless you really think those GTX turbos will be too laggy for you without the extra 0.5L displacement and insist on not changing turbos to something more suitable for a 3.0L, then go with the 3.5L. Otherwise, the built 3.0L is about the cheapest route in some cases. A Pampena Stage III motor isn't cheap in which case a 74 built Pampena motor would be the better option. I know it's hard to find a good machine shop at the same time so it's hit or miss if you end up buying the parts and have the motor done locally.
I always sell what parts I can when I switch setups so building a forged 3.0L motor and then deciding later to upgrade to a stroker isn't out of the question unless I'm too lazy to pull the motor.A simple approach makes for a fun ride. Sometimes you just can't help but want more though.
Building "for cheap" got thrown out the window when he went with these turbos over the bolt-ons.
I agree the 74 is the smarter way to go in terms of affordable rebuildability, but don't forget it's $1200-$1500 for the long block with all the accessories by itself. Then another $2500 for cleaning, honing, decking... Proper rebuild. Then you need rods and pistons on top of that... Then you gotta deal with the fitment mods for your exhaust, intake, oil pan and everything else.
Whether you go stroker or built 74, it's gonna cost $$. Just a matter if you want to deal with fitament issues or not.
what are your end goals? i would think on a 3.0 boost might hit by 3.5K
Agree on simple and fast, but unsure how going stroker with the 72 block changes anything on the simple end of things.
If i damage the crank, im gonna have bigger problems than the 1500 bucks for a new crank.
Unsure how stroking a 72 block no longer keeps it simple.
72 crank is weak in the power area my car will be, the 74 crank is significantly stronger. Im actually more interested in the stronger crank than the .5L of displacement.
You listed everything that is the purpose of going with a stroker. Of course power can be made with a 3L, ray made high 800's with his car.
pleeeeeease.
These GTX turbos were specifically picked for the 3L, they shouldnt be laggy at all. Fortunately for me, Ray is just a 6hr drive up the road from me.
74 block is out of the question, not dealing with the fitment BS of it.
The turbos are just a 63mm billet wheeled Garret with a T28 backend.
Jason
I vote stroker. At the end of the day, it's awfully simple to swap stock heads for upgraded ones later, vs having to pull the engine completely if you decide to go with a stroker later. As often as you've changed setups over the years, I'd go with the option that is easiest to change later, which also happens to be cheaper. Seems like a no brainer.
With the DR setup, the whole engines gotta come out to swap heads since you cant install them turbo setup with the engine in the car.
This setup isnt changing, its kinda the culmination of the past experiences with my cars, my experiences with my friends DR750 car and with talking with Matt in length about doing a setup like this for the past couple years and finally just doing it.
I picked the Garretts so i had a readily available off the shelf turbo thats easy to get almost anywhere, anytime. But these are new for 2012 and the smaller version of these, the 60mm put down 740 wheel at only 29psi on a 300zx so, these things should pack quite a punch!
Biggest reason i want the stroker and after reading some of Rays post on it and discussions with Adam is the 74 crank is so much stronger and resilient in the post 600awhp world which is the bottom end of where i want the cars power level to me.
Jason
Sounds like you decided on stroker already. Should be a fun setup.
If anything ever happens to my 3.0 (again!), I'm going with a 3.5 74. Doesn't seem like that much more work.
I've never really taken an indepth look at the 72 stroker. What's all involved? New crank, rods and pistons??
74 crank machined to fit the 72 block. 72 rods and custom pistons with a higher pin location to allow for the longer stroke.
Jason
