Looking for opinions.
Bought the car with unknown miles, larger fuel injectors but no controller, 13Ts w/o boost controller, by Carfax, I estimate 185k miles. Car ran before I started working on it. Forgot to do a compression test before pulling motor.
So question is, I plan on replacing bearings, along with a full 120k. Should I pull the heads and replace piston rings?
I have a lot of other things I need to spend money on first.
My thoughts, leave heads on (save cost of rings, head gaskets, machine work, etc). After car is running a bit, when the time comes, either through blown head gasket, or something worse, or I have the money, I pull heads and go stage 2, at the same time upgrade rods/pistons.
Figure right now since its not broke (or at least I'm not aware of it being broke) than no need to fix it.
Sent from my Nexus 7 using Tapatalk 2
