View Poll Results: Which engine
Voters
31. You may not vote on this poll
  • Built 72 with DR heads
    14 45.16%
  • Strokaaaah but with stock heads
    17 54.84%
Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 89
Thread: Engine Dilema...
  1. #31
    Delaware
    Thats the pricing from Pampena.
    Jason
  2. #32
    VR-3747 :D Not Verified
    Dayton Ohio
    i have to disagree, jason. ray charged me $550 to balance mine im pretty sure. maybe thats the machining to get the crank to fit as well? balancing the crank by itself is not all that expensive to do though.
  3. #33
    Delaware
    Yes, thats cutting it down and balancing it making it ready to install in a 72 block short of the block modifications. Apparently balancing the cut down 74 crank is a pain hence why they charge 600 just to balance it. NY labor rates also come into play also vs many other areas of the country.
    Jason
  4. #34
    Dayton Ohio
    hmm. ok. you know where i stand on the matter anyhow
  5. #35
    One fix at a time verified
    Kansas
    You guys are forgetting two things. 1) Ray uses Mallory to balance the crank. It's a very expensive material to make slugs for that get drilled and pressed into the crank. 2) Instead of simply drilling holes in the crank and pressing the weights in there, instead he drills through the side of the crank and press fits Mallory slugs. The reason he does this is because of the higher rpms with the extra stroke he was concerned about the Mallory coming out of the crank if he put it in the ends instead of through the side. That all takes quite a bit of time so of course it will cost more to balance. I would have to look back at my receipts but I believe it was $900 to balance and $600 for the machine work. It may have been the other way around. That was with a 10% end of the year discount also.
    Most shops just drill holes in the counterweight to balance a crank fyi.
  6. #36
    Stroker and run e85, it will make up for the lack of head flow.
    Current:
    1972 Chevy Nova
    2004 Ford F350 Lariat 6.0L
    1991 Stealth TT FWD
    1962 Volkswagen Beetle
    Previous:
    1994 Stealth RT/TT
    1999 3000gt SL
    1973 Volkswagen Super Beetle
    1976 Jaguar XJ6
    1991 Chevy S10
    2000 Ford focus
  7. #37
    Delaware
    E85 is a 140 mile round trip for me to the only pump :/
    Jason
  8. #38
    Man that sucks, maybe get some drums shipped to you if you have the room.
  9. #39
    Delaware
    WAY too much money in shipping. 400 dollars for 3 drums which i'll burn in a month.
    Jason
  10. #40
    Jan 2011
    az
    Jason
    400 for 3 55 gallon drums ?? From where ? That's cheap !
