Page 102 of 166 FirstFirst ... 25292100101102103104112152 ... LastLast
Results 1,011 to 1,020 of 1658
  1. #1011
    August 2010
    Chicago
    I know theres a few people using 2.7version of evocan, I'm also using 2.7 Ive got an issue...hoping you guys could help.
    I put the xml file in the datasettings folder and removed all the other files that were present. Like so..
    When I start evoscan I get this msg three times..then evoscan starts
    This is what it looks like when it starts..It looks OK..it shows 2 banks, etc..
    But when I try to start the logger this msg comes up..
    So I can't datalog properly. Otherwise without touching anything I'm able to log but not with the correct evoscan settings. Funny thing is, when I go back to the datasettings folder, all the other files that I deleted previously show up again..What can be done? Thanks
    ALSO: I don't know if it matters, Ive got like 3 evoscan folders. One is under owners documents, the other is under program files and the third is under program files(x86)...all of which I've pasted the xml file into.
  2. #1012
    why don't you use 2.6 until the 2.9 file is release. If you email hamish he'll send you a license for older versions.
  3. #1013
    Uninstall all your evoscans and Do a fresh install. Put it into the C:\ directory this time instead of Program Files.
  4. #1014
    August 2010
    Chicago
    Yeah I was reading about that in the first post...was gonna try that next..thanks. I'll let you know what happens.
  5. #1015
    August 2010
    Chicago
    Got 2.6 loaded up, just went out and did my first datalogs..wooohoo!! I'm psyched! Thanks!!
  6. #1016
    The scaling is messed up for those table you sent out. I switched the scaling back to blobbits and it worked fine. BUt if I left the EnableDisableBits it didn't work. Can you post the scaling info to put in the scaling section?
    I was about to change mine over, so is this correct or should I wait for the new one he is going to post?
  7. #1017
    Oct 2010
    St Louis
    I would wait. fyi, I was on v 2.7 until I created v 2.9
    www.ClonedECU.com
    Get Chromed!
    1999 3000GT VR4
    Glacier Pearl White
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
  8. #1018
    www.chromedecu.org verified
    DFW
    Quote Originally Posted by 99 vr4 View Post
    Oh, you created the 2.9 datafile?! Good work B!
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  9. The Following User Says Thank You to Jesters Deadd For This Useful Post:
  10. #1019
    Just updated this post with the new periphery tables. You guys will need to delete the old ones and replace the code with these. Adam, I remembered the scaling this time.
    http://www.3sgto.org/f2/so-who-wants...tml#post138055
  11. #1020
    August 2010
    Chicago
    Hey guys..check it out! VD log of my 19T's...
    http://www.3sgto.org/f2/virtual-dyno...-4-a-9173.html
