Results 1 to 10 of 14
Thread: Stock ECU, O2's and Tuning - Advanced Class
    2004/5?
    SW Connecticut
    Hey guys, so I have a LOT of questions . I'm mainly seeking a deeper understanding of this car's stock systems to help me determine what may be limiting performance. Warning, the following questions may be numerous and incomprehensible.
    I'll start off with the state of my car - It's essentially what you see here in my sig. I am not running any kind of ECU piggy back system to control Air/Fuel. I am running stock oxygen sensors (no wideband). I AM running a fuel pump hotwire as sold by 3sx, as well as an AEM AFPR.
    My intake system has been upgraded quite a bit including an EGR delete. My eggstoast system is 100% stock save gutted pre-cats.
    Now, I've been doing a lot of reading regarding fuel trims, and I understand how they work more or less. I've read a few times that pretty much bone stock 3/s cars have been known to run in the 80's for all fuel trims. The reasons I hotwired my pump and installed an AFPR, are because I am trying to (1) eliminate knock, and (B) obtain as close to 100% fuel trims as possible. I have been reaching for the 100% goal under the assumption that this is where the car will operate the best from an air/fuel ratio standpoint. Is this thinking correct, or should I be shooting for a leaner (>100%) or richer (<100%) tune?
    My current fuel trims from my most recent 10 minute log are: Low – 81.2/83.5% (varies) Mid – 96% High – 96.8/98.4% (varies)
    I'm curious if it's possible to log the front bank fuel trims and the rear bank fuel trims using HHH with a 1g, and if it's worthwhile.
    Admittedly, I do not fully understand the relationship between fuel trims and the air/fuel ratio insofar as what ratio varying trims are an indication of… or if they are even a reliable indication of said ratio. I’m currently under the impression that my low fuel trim is pegged so low due to my deleted EGR system causing a decreased quantity of intake air over what the stock map had planned for. Is this an accurate assessment?
    I’ll also mention that I do get high counts of knock on HHH logging occasionally (20+) REGARDLESS of boost level – it is very unpredictable and there seems to be no apparent trend. During these knock readings I do not notice a decrease in power or hear any audible knocking sounds. When I told this to the guys at Pampena, they responded that they do not tune cars using such logging software, don’t trust it, and they pretty much just do it by ear. Given this approach you would arrive at the conclusion that there’s nothing wrong with my car, and in fact I have been driving it for years under this condition with no problems, yet I’m still apprehensive to step on it while not logging for knock.
    My thought is that I’d like to continue running my ECU with no piggyback, and stock O2’s for as long as possible due to simplicity and to save money. I have a very limited ‘tuning’ budget, yet this is one of my only and biggest hobbies and my money will find its way into the car at some point or another. As such I try to very carefully plan all of my mods. This car is my daily driver, so it must remain reliable.
    That being said, a piggyback AFR controller and wideband O2 are not out of the question for future plans. While I’d like to keep my current setup as previously stated for simplicity sake; if installing such things will increase drivability and reliability I’m totally open to them. I’d like this thread to focus mainly on my previous questions, but I have a few quick ones regarding these items.
    I’m under the impression that a wideband O2 with gauge such as AEM’s is essentially a standalone unit. The O2 would have no input to the ECU, or any air/fuel controller. It is simply an instrument that will give a much more accurate Air/fuel ratio read out than stock oxygen sensors, and provide a good target for tuning using an air/fuel ratio controller such as an Apexi SAFC. Similarly, an SAFC would have no direct input to the ECU, but acts more like an independent variable that would later affect the dependent variable that is fuel trims seen by the ECU. Is having a wideband pretty much useless without a fuel controller, or could having a wideband to aid in adjustment of my AFPR actually be of use to me? Does a wideband oxygen sensor replace the stock sensors, with the stock sensors getting unplugged thus removing any signal to the ECU, leaving all adjustment up to a piggy back fuel controller?
    That’s everything rattling around in my brain at the moment. I’m sure I have and will have tons more. Thank you for any and all information!
    -Caleb
    . 1992 VR4 - Java Black Pearl paint (2004 STI) with combo '92/'96/'99 custom front end .
    . Fittipaldi Force or 5Zigen FNO1-RC wheels . Cianci rear strut bar . K&N intake . DNP pre-turbo hard pipes . DNP hard intercooler pipe kit . Greddy Type RS BOV (recirc) . HKS EVC Black Limited boost controller . Vacuum reduction with all silicone pluming . EGR block off plates . Hot wired fuel pump . AEM AFPR @the rail with Robbeck adapter . Fuel rail loop . Tanabe knockoff down pipe . No cats . Single Turbo Flamer full 3" cat back . RPS Max pressure plate with street disk . Seattle92VR4 solid motor mounts . '99 Lifters . R1 Concepts slotted rotors . Supercar Engineering brake caliper stiffening bolts . HHH data logging . Red Line fluids .
    I Kill Threads verified
    Wichita KS
    Without having a fuel controller theres nothing you can do besides increase or decrease your fuel pressure, but fuel trims below 100 mean it's taking away fuel, above 100 means its adding fuel. 100 is 14.7 afr. You could get a wideband but without any fuel controller you would just see your actual afr. Now you can wire it in to log but again, with no fuel controller it really does you no good.
    To address the issue of knock check to see if timing is being pulled when you get knock, if it's not then you don't really have knock.
    1992 3000GT VR-4
    West MI
    Knock that has no common denominators and that is completely sporadic may be considered false knock. You may want to look into purchasing oem o2 sensors, it helped me a lot a few years ago.
    92 3000GT VR4
    Matt
    A fuel trim of 100 means nothing is being subtracted and nothing is being added. If all your fuel trims were at 100, you would not need an o2 sensor anymore.
    If your engine combustion is running a bit rich (based on O2 readings), the ECU will reduce the fuel trim number until it reaches an AFR of 14.7. And as you would have expected there's an absolute minimum and maximum value for fuel trims. On 1st gen ECU I think the range are (80 to 120) and on the later generation ECU the range is even greater. So if you see a low fuel trim value of 80, this would indicate to me that at idle or cruise you're way too rich. Common issues are hotwired fuel pump relay & upgraded fuel pump overwhelming the stock FPR causing fuel pressure to increase beyond stock value. But in your case you stated you have an aftermarket FPR, my guess is your base fuel pressure is slightly too high, or you have a slight intake leak, or you have a small exhaust leak (giving the o2 sensor slightly wrong reading), or your O2 sensor is lazy and worn.
    2004/5?
    SW Connecticut
    Quote Originally Posted by Goallie11 View Post
    It is pulling timing – my last log read a peak knock count of 24 with timing pulled to 6*.
    Quote Originally Posted by sublime_whatigo View Post
    My O2 sensors have been replaced with OEM fairly recently, maybe a year or two ago, I’m quite sure they’re still good. In the same log mentioned above, rear O2 reading was level at .89V, and front was the same.
    If my ECU is registering knock from the sensor, wouldn’t it pull timing whether or not it was “real”?
    This trim reading is what resulted in my installation of the AFPR, thinking it would be problem solved.
    This is along the same lines of my thinking, which led me to the guess that my deleted EGR was causing the discrepancy in my Low fuel trim due to a slightly decreased intake of air. I wonder if this is something other people have seen as well with the same set up? I’ll try to decrease my fuel pressure a little more – I feel a little safer now that I have a logging computer up and running again. If neither of those make sense/work, I’d be pretty stumped. My intake is pretty solid, exhaust I guess is a possibility but I just checked it out the other week and didn’t see any noticeable issues from the under-side.
    I appreciate your help guys, thanks.
    -Caleb
    Wichita KS
    What fuel pressure are you running? Stock levels are around 36 psi with the vacuum line connected, and 45ish with it disconnected.
    With you're timing being pulled to 6 I would definitely think the knock is real. I get random knock but only 1 or 2 while driving, I'd say something is up with yours.
    Pull the front heat shields and check the mani for cracks in the middle portion. This will add air to the exhaust and cause the o2/ecu to add fuel.
    I get phantom knock occasionally up to 22-24, but only at low rpm/load. This is not uncommon. If you are under load and getting this amount of knock, there are other issues. You say your intake system is sound, have you confirmed with a pressure test? What are you controlling boost with, if you are, and how much?
    Quote Originally Posted by Rom3BreaK View Post
    That's incorrect!
    If your bone stock car is running in the low 80's there's something wrong. There shouldn't be any reason for the ECU to take away that much fuel. I'd first suspect a faulty injector or cracked exhaust manifold probably.
    Intake leaks generally cause the ECU to add fuel to make up for the unmetered air getting sucked into the motor.
    2004/5?
    SW Connecticut
    Running stock levels, set by me and confirmed @ Pampena during my last visit.
    I’ll definitely be checking this ASAP, unfortunately I forgot my socket set in my dad’s garage last time I was doing work… apartment buildings FTL. I have pressure tested, and I’m controlling boost with the HKS EVC you recently sold me; was previously using a crappy one at waste gate pressure – same knocking conditions. That was part of the reason I upgraded to the HKS, but it turned out the problem wasn’t just a crappy EBC!
    I had seen it in some pretty old threads from some guys that definitely knew what they were talking about, but that doesn’t mean there definitely wasn’t anything wrong with their cars. The thing that I find the strangest about my trims is that it’s only around 80 for the low fuel trim. I’ll be checking out the exhaust manifold first and from there I guess I’ll move to replacing injectors ($igh) unless there’s any other suggestions. Is the stock exhaust manifold cracking a common issue, and would bad motor mounts be the culprit of this? I’m pretty positive my stock mounts are good having watched the engine while on the dyno. Car does have 130k on the clock though… VAST majority are highway miles, 12k + miles this year alone so far. Front and rear solids are on my short list, though.
    Really appreciating the help!
    They just crack from being heat cycled so many times. Just a casting issue from mitsu...
    The low trim is the idle trim. Anything under 100hz the ECU uses the low trim.
