I'm considering the idea and researching my options. Just looking for explanations, pros/cons and opinions here...
I've never used one before, but considering using one on my tt conversion. How do they work? Are they pretty much all the same as far as quality or functionality? It seems to me that it could reduce oil filtration? Another concern would be pushing the filter too low and it could possibly get snagged on something, especially if lowered.
Here's one I was looking at.
1/2 NPT 0.5"ALUMINUM OIL FILTER BY-PASS M10x1.5 SANDWICH ADAPTOR PLATE KIT BLACK | eBay
Is this 1 feed, 1 return? Or 2 feeds and you send the returns to the oil pan? What are the bolts on the side for? Are they for securing it to the extension or adjusting/shutting off oil supply or for something else like sensors?
They are not all the same. The one you posted is for oil cooler. There are no ports that just flow through. There are some are basically spacers and all the oil just flows through and you can mount sensor on it.
