. 1992 VR4 - Java Black Pearl paint (2004 STI) with combo '92/'96/'99 custom front end .. Fittipaldi Force or 5Zigen FNO1-RC wheels . Cianci rear strut bar . K&N intake . DNP pre-turbo hard pipes . DNP hard intercooler pipe kit . Greddy Type RS BOV (recirc) . HKS EVC Black Limited boost controller . Vacuum reduction with all silicone pluming . EGR block off plates . Hot wired fuel pump . AEM AFPR @the rail with Robbeck adapter . Fuel rail loop . Tanabe knockoff down pipe . No cats . Single Turbo Flamer full 3" cat back . RPS Max pressure plate with street disk . Seattle92VR4 solid motor mounts . '99 Lifters . R1 Concepts slotted rotors . Supercar Engineering brake caliper stiffening bolts . HHH data logging . Red Line fluids .
So I finally got around to removing the heat shields, and there's definitely a split in the manifold, although it's difficult to tell how bad it is - picture quality from beneath looking up certainly wasn't good. I took a sawzall to the heat shield because I didn't have time to screw around, that's what the marks on the left are.
So I guess next step is to remove the manifold, how long can I expect it to take? Any tips?
Also, anybody foresee problems leaving the heat shields as pictured for now? I know it can allegedly effect the paint, any other concerns I should have?
Any suggestions for a different heat shield orientation/option/method of cutting so that in the future it's not such a pain to remove but still does its job? I'm not even really sure how I got the thing off with just the one cut down the middle...
On a side note, I can't believe how hot the manifold gets after ~20 seconds of the engine running. Couple minor burns over here.
Thanks,
Caleb
So I realize this thread has devolved from it's title, but I thought I'd offer an update tonight, after I FINALLY got a chance to dig in to this. Manifold is removed and will be taken to the welder tomorrow, all in all the split is very small, nothing noticeable would have leaked out/in it I wouldn't think, but will certainly need a bead ran to seal it up nicely.
On another note, I did find another problem that I can't believe existed. I've owned this car for a long time - over 7 years, and this had to have been this way the entire time. On the front turbo, the band clamp that holds the two halves of the turbo was just hanging there completely unfastened. on the inside of the clamp it's black with soot - presumably from leaking exhaust - 360* around. I don't know what a previous owner was thinking about or doing here, I'm totally dumbfounded that somebody could be so stupid. The fastener for the clamp is in fact broken, and from the way it was positioned, it's clear that this was acknowledged and "installed" anyways. It looks like I finally found my issue.
