Page 242 of 892 FirstFirst ... 142192232240241242243244252292342742 ... LastLast
Results 2,411 to 2,420 of 8916
  1. #2411
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    I would say it's a combination of that and the heat. The condition of the hose will be fine, but it will get that "yellowish" hint to it. Would be a great idea for a show car.
    What about a Nylon hose? Like a stiffer, and manufactured for the heat..
  2. #2412
    today i have done nothing so far, altho i may be taking the car to six flags.
    yesteday i took the wife for her first drive in the newly installed seats however!
    drove me n the wife down to the city and back to go visit the barnes foundation.
    our observations after a few hours in the seats:
    me: these seats will be just fine for long drives, no cutting off circulation or butt numbness. great lumbar support, very comfortable yet firm cushioning and they really feel like they secure you without any discomfort. very happy with the change. heavier folks may have some issue with these seats however, at 6' and 185lbs they fit perfectly.
    wife: the difference took a little getting used to but after about an hour in the seat she thinks it is an overall improvement. she says compared to the old seats she feels more support and thinks it is easier to get in and out of the car.
    so there's our 2c
    and now for some pics installed!
    they feel fantastic. may at some point install roll bar and harnesses, let's see what happens at the track next week.
    93 dodge stealth r/t tt, 457awhp and 424awtq on 93 pump
    13t turbos, 550cc injectors + afpr + walbro, maft + z06 maf + safc, intake + fmic + exhaust,
    lightweight flywheel + crank pulley, jackhammer timing gears, pampena short block, 93 pump
    94 dodge stealth r/t na, used to drive: 13.9@100
    60 shot of n2o, 360cc injectors, safc + tt fuel pump, intake + exhaust, lightweight flywheel + crank pulley, 93 pump
    93 dodge stealth r/t tt: personal parts car
    03 ford focus se: beater
  3. #2413
    matter of fact i may make a thread about it
  4. #2414
    SKADOOSH!!! verified
    Prince George
    Those look very similar to my Recaro's, perhaps the newer model out. I like mine a lot as well, I can do a 10 hour trip in them no problem!
    Photobucket
  5. #2415
    bslade
    Guest
    Trying to find a new route for my A/F gauge Oxygen Sensor thru the firewall or floor to the new bung location on my exhaust.... The two holes in the firewall on either side have too much stuff going throug them already to add this thick cable...... sigh...... Sensor bung used to be on the test pipe but it suggested I move it closer to the engine, so they installed a new bung for me there. I thought I could do the rest myself.
    Miss my A/F gauge.... I have to get from the drivers side floor over to the exhaust under the firewall on the passenger side.
    If anyone has ideas it would be appreciated. A trip to the wreckers usually helps me get a better view of where things are on my car too LOLOL.
    Thanks,
  6. #2416
    Quote Originally Posted by bslade View Post
    Thanks,
    thar be a hole behind the ecu on the floor that works perfect. Factory used it for the narrowbands in the federal NAs.
  7. #2417
    May 2012
    Central Fl
    Quote Originally Posted by chansigril View Post
    so there's our 2c
    TRADE ME SEATS! Lol those are very nice, how much did you pay for them? Thinking about putting my leather seats up for sale to get some similar ones.
    1993 3000GT SL
    Mods: 95 front end, Robomodded Glass Headlights, VIS CF hood, Megan Racing Coilovers, relocated battery, short ram intake, VR4 Plenum, OBX LSD, OBX longtube headers, test pipe, 3SX underdrive crank pulley, Fidanza 9lb flywheel, Spec stage 3 clutch, solid lower engine mounts, 80a poly filled upper/trans mount, poly front sway bar bushings, Momo steering wheel, 3rd gen lifters, Konig 18" wheels, 4300k HIDs, gutted trunk, AC delete, PS delete, Cruise Control delete, ABS delete, SRS delete.. Plus other random stuff.
  8. #2418
    No sheep are safe tonight supporter
    Dandridge, TN
    so there's our 2c
    What did you use for rails? And how's the position compared to stock? Do you sit higher, lower, about the same?
  9. #2419
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Gave it a much needed bath.
  10. #2420
    Quote Originally Posted by J_Parker View Post
    those are from an 03-05 mitsubishi lancer evolution, they're the only seats i've seen that look like that. mebbe you have the same seats?
