Best mods:
-Planning for me is key. Unless you are reinventing the wheel on a particular setup, mostly everything has been done and documented. My white car is, and always will be, a street car. Creature comforts are to me: A/C, interior, radio, heat, cruise control.
Things I like that I want to keep: adjustable suspension, abs, SRS
-Things that I've pulled that I don't need: Emissions equipment, but my car is a spring/summer/fall driver on ethanol gas, so the emissions should be very low. Having full control over the tune with the AEM afford me the luxury to remove clutter from the engine bay, while maintaining form/function/reliability.
-Solid motor mounts This car is 20 years old, a little vibration doesn't kill me
Worst mods:
-TD05 based 50 trims over the transmission. Talk about relocated heat pumps that cause problems
-Not putting full out slicks on my blue car when it was in "kill" mode, still kicking myself for that 11.45@135.76 "best" 1/4.
-Roll cage down bars (halo) in front of the dash. Looks cool, but should have went through the tweeter holes and put components in the doors
-Upgraded sidemount air heaters.
