Okay here's the problem, after replacing the bent valves and at the final stage of finishing the car i notice there's a tiny little shield that i forget to put on the head. I'm wondering if it's okay to not install it for now, and if i don't is there any risk what so ever ? this is the piece and it goes under the last sprocket between the head and the last bolt for the timing cover.
It's 2 bolts....why not re-attach it? The engineers put it there for some reason.... Just my .02 Bob.
95 Caracus Red Spyder VR4 (sold 6/12/21 ) Cianci FG Viper Hood/Aerocatch Pins Quad Carbon Fiber Tipped Borla Catback Stock 18" 6 Spoke Chromies K&N FIPK Indiglo Gauges JimVR4's Remote Start/Top Op Computer 92 Wheat Beige Metallic Stealth TT (sold 6/14/20 ) OhioSpyderman Short Shifter (in both!!!) SBC-iD Boost Controller (in both!!!) Oldest son - 94 Danube Blue VR4 (sold 10/19) Middle son - 93 Panama Green VR4
daerdevil_1987
yea , i need to take the timing belt, sprockets, upper intake and valve cover to get to that.
LOL... I removed those years ago, including the ones between the heads. Never had any problems with them not being there.....
Check it out on Youtube!! 93 Stealth TT - The Stealth Project Renegade Tech Works ECS Controller on Intrax Springs Chrome ECU Hybrid 13g's EVO 560cc Injectors Spec Stage 3 clutch Ninja Performance Output shaft & Input spool Ninja Performance Solid Tensioner & Gates racing T-Belt CX Racing Dual Core FMIC Megan SS Exhaust Fidanza Cam Gears and Clear Covers 3rd Gen Lifters HKS BOV K&N FIPK Maximal High flow converter Walbro FP & FuelLab FPR Maximal and Seattle Solid Mounts All -6an Lines Custom -6AN coolant neck lines AWS/ABS/Cruise Delete MP Rear Control Arms SS Brake Lines 99 Front Conversion 2nd gen Rear Bumper 99 Combat Wing Complete interior LED Swap Skillard Fuel channel Oohnoo FPR Bracket . . More to Come......
Not so much a heat shield as a debri shield from crap getting into the belt area. It's also the only support for the lower timing cover in that area. Bitch of a job to install now, but without, lower cover may make contact with the belt which may end in tears- Id hesitate to run without-
Interesting. I don't think my engine has that.
Check out my dyno collection site. Over 70 dyno charts! 2013 January Car of the Month - All 3s 2011 November Car of the Month - Interior If my links/photos don't work replace penguinhosting.net/~bigmac with primaryboost.com Uncut 3000GT keys for sale! Various colors!
I decided not to install it now, i need a new timing cover and upper engine mount, so I'll put that back when i get the parts.
I think you'll be fine without that one, it's in an interesting spot in the back where imo debris can't really get in from. I'd hesitate to run without the metal cover in the middle because I find stuff down between the heads there enough to really want the shield. The lower cover is plenty stiff and won't contact the belt without it, wouldn't be concerned at all.
Forum Rules
