www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
Would this be for the sl ecu also.
Just flashed my SL ecu yesterday installed it in my 95 VR-4 and it started up great.It was idle surging slightly and it threw a CE light after a few minutes for a crapload of stuff. All 4 oxygen sensor heater circuits, EVAP purge solenoids, EGR, MFR controlled air and fuel metering and Intake air temp and mass air flow sensor codes as well. 11 codes all together..lol on top of that I drove the car 100 miles highway and got crap gas mileage..no wonder...The evap and EGR stuff I can disable on ecu flash..what should I do about the o2 heater circuits and MAF codes?
Fan-frigging-tastic news!![]()
with my stock ecu my car runs perfect. NO cel or nothing. I'm still on the stock maf, injectors, pump, etc..I'm sure its probably some setting or something on ecuflash...?? Because I don't have a MAP sensor, mine is a 95. The car also doesn't feel right on WOT...its got a backfire out of the exhaust at like 3500 rpms and i think its cutting timing..its all interelated
