Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: I Fail...
    Quote Originally Posted by cjbyron View Post
    Yeah, happens quite a bit from my experience. Had two incidents of this very thing this year on some VR4s. I use a digital snapon torque wrench so maybe it is a bit easier to see them stretch. You can watch the torque go up and then drop right back off while they stretch. It is usually not every bolt holding on the oil or water pump but one or two. Which is enough to cause problems. Bolts are relatively cheap so I replace them w/o concern if there is question. Also had a tensioner bolt stretch this year too. Again, on a couple VR4s. These days I keep a selection of new ones ready to go as needed.
    Maybe it is the digital torque wrench that allows for more easily noticed? I dunno. But the difference is immediately noticed, and corrected, by getting new bolts in there that hold. 'voila, problem solved.
    Interesting. Yeah, the digital torque wrench is undoubtedly the difference. So you're saying the bolts never make it to the target torque? At what torque do they begin to stretch?
    Seattle, WA
    Sometimes they make it. But they fall right off again. I can actually feel it in the wrench while also watching the number fall as pressure is still being applied. Watch it go up and either get to or approach the target and then once further torque is stopped the number just drops down. I don't recall exactly to what. Something like 5 or 6 IIRC. When that happens it doesn't matter what gasket or sealant one uses. It will likely leak.
    I don't think it is a fluke or uncommon though. We've done probably a dozen or more 120k (high performance and standard) in my shop this year. Because these bolts stretching became more than a one time thing I have one drawer just for these bolts in my OEM new parts bins. Water pump/oil pump bolts and tensioner bolts.
    I keep these as they are the ones that have stretched more than once: MF140027 and MF140040 (oil pump bolts, about $2 ea), MF140036 (water pump bolt, again, $2), MD173607 (timing bolt train bolt, about $3.50 ea), and MD145360 (tensioner bolt, has unique shoulder, around $8 ea). Prices are estimate dealer prices. Cheaper of course if you have a shop account with your local dealer or maybe an online dealer. Either way, they aren't expensive considering the alternative (leaks and doing it all over again).
    Interesting. If what you're saying is true, (a) I'm glad I don't do this work anymore and (b) The Right Stuff is even more amazing than I thought (never had any sort of leak following a 120K)! haha
    Seattle, WA
    Personally I prefer the Mitsubishi Gray RTV.
    But TRS has it's place and many swear by it. It's a PITA to get off I know that! LOL.
    Not every service job has had those bolts stretch by any means. I hope my post didn't sound like that is what I experienced or meant. But it happens enough (to me) that it is worth paying close attention to. Because if you lose the torque by the stretching of the bolt(s) then no matter what sealant you use it has a strong possibility of leaking. Much will depend on what the bolt will hold or not. Each situation will be different.
    It is definately a testimonial though for always using a torque wrench (which surprisingly many don't seem to do on a lot of areas and then wonder why their oil pan or valve cover or whatever leaks from being bent, overtorqued, or bolts break!). That overtorquing practice might be the reason for some oof these bolts stretching (overtorqued previously and exceeded the bolts capacity).
    I always use a torque wrench, but have yet to splurge on a digital one. You just made the most compelling argument I've heard. Which model snap-on torque wrench do you use?
    Seattle, WA
    I use the Techwrench type. The FR240 1/4" drive for smaller stuff (2-20) and the FR100A for the majority of everything else higher (20-100).
    Snap-on Tools
    For above 100 I have a craftsman digital 250 that works well (but really eats up batteries).
    Sometimes you can find good deals on them on eBay too but still a lot more money than old click style (but worth it IMO)
    You get real used to the niceties of the digital ones. Much better than the click click ones. Plus you don't have to reset back to zero every time you put them away. All automatic and they shut themselves off. less to worry about or bother with.
    Dying ain't much of a living, boy.
    Josey Wales
