So, I've finished my 3rd attempt at eliminating leaks and to no avail...did the 120k service, first attempt, cleaned and prepped both surfaces with 600 or 400 (can't remember) wet-n-dry, used gasgasinch on gaskets, torqued everything to spec, let sit over night before adding fluids and starting, had a small leak after a month, so tore it all back down, used fel-pro gaskets, cleaned and prepped the same, this time, installed gaskets dry (no sealants of any type) torqued by feel, sat over night before adding fluids and starting, ended up using an old Right stuff on the oil pan, that didn't dry so it leaked like a sieve, tore it down to find the other gaskets were leaking some as well.....
THIRD TIME'S A CHARM...fel-pro gaskets again, this time used Roloc green discs on everything, nicely/evenly scuffed up, used permatex copper spray on gaskets, over torqued everything by 2 ft/lbs, let sit over night before adding fluids and starting...after two months, leaks again...
What the hell am I doing wrong here? Only thing I can think of is, after full assembly, run engine to operating temp. let fully cool, then go through and re-torque everything??
I can't stand leaks and there's no excuse or reason to have any, not even the smallest of leaks, I've tried with and without any sealants, torqued to spec, torqued by feel, over torqued...I dunno, I'm baffled, I've never had this much trouble with anything, I dunno what I'm doin wrong here, I feel retarded...*sigh*
What's your process? Also torque wrench is -/+3% like most so I wouldn't think I was using inferior tools and Fel-Pro is good stuff from what experience I've always had before...
