Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: tranny removal?. clutch chatter..
  1. #51
    I’m going to try a different oil and see if it makes any difference. I’ve changed it once already to check for metal. It’s time to do it again anyway.
    In my own home
    I dunno, that sounds like the TOB to me. It is on the shaft that goes into the body of the trans, and isn't connected in to the bell housing, so I could easily see the sound traveling down the shaft into the main case and you hearing it there best with a scope. My rattle sounded just like that, and when I replaced the TOB and lubed it some, the sound went away for a long time. Also remember, it goes away when you push the clutch pedal. Also, you said the car seems to shift fine otherwise. If something inside the trans were really so off that it was rattling, I doubt you would be shifting good. Inside the trans, things are rotating and meshing together. A rattle/loose part in there I would think would make for trouble shifting.
    WWW.3sofflorida.com is the new home for 3000GT & Stealth Enthusiasts in Florida. Sign up today. But also stay on this site too. Think of it as having multiple homes. Its a sign of being filthy rich.
  3. #53
    Never finishes any verified
    Wake Forest, NC
    TOB and Input shaft bearing are brand new. Still sounds like shit so neither fixed the problem.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  4. #54
    Now this is what I was told by a friend but he replaced the TOB and it still did it. Later he pulled it out and put a liberal amount of grease on it and it went away. I assume it’s true but it might not be your problem or mine. Did you use an OEM TOB?
  5. #55
    Wrench Monkey Not Verified
    Rochester, NY
    Quote Originally Posted by enollava View Post
    My thoughts exactly. And there's really no way to tell the difference between a TOB rattle and a clutch hub rattle. They both act exactly the same. Stock clutch hubs are known to rattle, ask RayP.
    Did he pull it out to replace the clutch the second time? Or just to lube the TOB? Did he lube it the first time?
  6. #56
    Quote Originally Posted by TwIzTeD_3kGt View Post
    From what I understand he pulled the trans to inspect the clutch TOB ect. then lubed the shit out of the TOB and put it back together. I can call him, I haven't talked to him in a while anyway.
