Results 1 to 10 of 25
Thread: Potential of 13G's
    Potential of 13G's
    I know we are talking about one step above the 9B, but I am curious what can these net HP wise?
    Thank you.
    Twin Turbo verified
    Melbourne, Australia
    I heard 50hp more than 9b.........
    Waiting install
    Build Thread
    Keyan got 420awhp on pump..... Really impressive #. I would also like to know DSM 13g #'s compared to the regular ones.
    iowa
    400hp should be attainable with minimal mods compaired to 15gs. maft, some evo 560s and bpu
    Quote Originally Posted by nodoze View Post
    hell, you don't even need 15g's. 13t's will do that easy. ask vr3.9.
    iowa
    sorry was saying you dotn need as many mods to run 13gs as u do for 15gs
    Feb 2011
    DFW, TX
    560's are too big for 13G's. Take a bit of advice from Trevor, and "check your ego at the door" and get properly-sized injectors.
    For 13G's, DSM 450's, Walbro, eBay downpipe, & SAFC will reasonably and safely net you some decent numbers. That setup can be had for <$500 if you shop around.
    my 550s for the 13gs work fine.
    the timing advance is awesome.
    Madison Heights, Mi
    13's max at about 22psi. IIRC 450's can not provide enough fuel for 22 psi. 450's have proven fine for me with room to tune. (I tune 15-16 psi)
    (all this assumes stock fuel pressure)
    Quote Originally Posted by Alan92RTTT View Post
    As you can see Alan I learned something new about my car.....is there any way to identify the cc rate of a fuel injector?
