I have an issue with my Innovate LC1 wideband at WOT.
Cruise conditions show a consistent 14.7-15.2. Once I WOT it, AFR's either stay exactly the same, or LEAN out to around 16-17. As soon as I let off the throttle, the AFR's dip down to around 10 and immediately return to ~14.7 at cruise.
Both exhaust gaskets to the DP are brand new. I have no knock on the logger, and the car pulls strong with no timing retard. Obviously, 16-17AFR at WOT would blow my engine, so it's just not right. The unit is accurate for closed loop operation. Why is it doing this at WOT only?
