Long Term Fuel Trims....The ECU cannot CANNOT directly change the Injector Duty Cycle (IDC) based off of fuel pressure changes. Simple as that. In order to do so, the ECU would need an input for fuel pressure. It does not have this (I know that you know all of this G, just stating it for others). Thus, the ECU can only INdirectly change the IDC based on fuel pressure changes. How does this happen? The increased fuel pressure results in increased fuel delivery to the engine. The ECU sees the rich condition via the oxygen sensor. The ECU then applies long term fuel trims (LTFTs). The LTFTs result in a decrease in Injector Pulse Width (IPW). The decrease in IPW mean less IDC. This is true for closed loop operation. This can also be true for open loop operation so long as the ECU has spent enough time in the higher load areas to apply a correction there (which doesn't happen much when you remove the delays).
