Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 98
Thread: Flash tuning results on a stock 99 VR4
  1. #31
    July 2005
    Arkansas
    Right. ....but most people don't run a regulator.
    Yeah, the main issue is the cat itself messing with the readings. My cats are still in place.
    Brett's is just an older version of mine which is a revised version that gate started.
    I'll just send the code to add to the xml.
    Yeah I've edited a few things myself, just to my liking, just dont want to do it all again
    Why not get a test pipe? Not that hard to replace the main cat. THough you could run it in a rear location. Sensor life will be deminished, but it'll give you good readings.
  2. #32
    Yep I understand. Any new updates I come up with I'll just send you the code.
    I have a full exhaust already with a dummy cat but it won't bolt to the stock pipes. Unless someone wants to let me borrow theirs with a bung in it, it's not really worth spending the $$ on.
    The local awd dyno has a tail sensor they use but I can't pony up $100 to rent the thing for an hour.
  3. #33
    Quote Originally Posted by J-Groove View Post
    I will be pulling the ECU tonight, Aaron has me wondering, I didn't know the '99 ECUs were little black plastic boxes. haha
    I have a '99 VR4 and my ECU's exterior is no different, in appearance/size outside the actual harness connector, than previous years....or did I just misunderstand?
    * Evo8 MAF * TD04-16T * Delphi 780cc * FIPK * Full Custom Exhaust * Hotwired Supra FP * Megan CO *
    * GReddy FMIC * Nitto 555's * Avic Z3 * BlackStealths LCD/BC *** All else stock *
  4. #34
    July 2005
    Arkansas
    Quote Originally Posted by Simace View Post
    No. A lot of the 99s had the later style Mitsubishi black box ECUs. All the real 99's I've seen, and all the Montero and Diamante ECU's from 98/99 were this style.
  5. #35
    my 98 has the black box as well
  6. #36
    Never knew that. Do you think it's attributed to Cali-spec vs Fed-spec? Or is it in the production run?
  7. #37
    They dropped the Cali-spec vs Fed-spec thing when OBD2 became a gov't standard.
  8. #38
    Here are the pics of my ECU
    1 thing, okay this looks funky, 2nd thing, THANK YOU TO AARON! For telling me that I needed 4 dimes to open it up. Made it very easy.
    Is it true that there's a finite number of times that these things can be reflashed?
    Steve
    Nope.
    Edit: turns out there is a limitation but it's not significant enough to worry about!
  10. #40
    Riding topless!! verified
    Owned 8 3s since 2005.
    Corpus Christi
    I would disagree with that a bit. For all flash chips there is a limit but it's usually so high that you will not reach it. For tuning I would hope you never could unless you flashed it every day for the next 10 years.
