there are many cars that use solid tensioners i see no reason why this can not be implemented on a 6g72, as for tension just use the old method, grip the belt finger and thumb at its longest straight point and twist it it should go no further than 1/4 of a complete twist, this should be a good tension.
anyone want to confirm this? this was always the method of tensioning older cars with solid tensioners. any less the belt is too tight and will whine, any more the belt is too slack and will slap.
it sounds feasible that the old stock is now failing, but really if the tensioner has only covered so many months /weks/ miles. then you should be able to present this back to mitsubishi, its a faulty item and they should warrant it.
