A couple of weeks ago my car was running just fine, until I pulled into my driveway at which point it just died. I tried to start it back up and it did nothing but crank. I finally figured out I had no spark. I replaced the coilpack. Same thing, no spark. Then I replaced the CAS. The car started up and shortlly after died! And now it will just sit there and crank but not start! SO now I have spark, but no fuel. I have fuel to the rails so I assume that my injectors aren't firing?
Here's a video of me testing the spark. That should good enough spark to star the car? correct?
Also, in the video, what is that noise right before I crank it and right after. It happens when I turn the key to accessory
http://tinypic.com/player.php?v=2nqwpxd&s=7
