Results 1 to 9 of 9
Thread: computer ecu mounting position/location?
    Dec 2016
    got the center console out and the computer/ecu is just laying in the front, how is that mounted (anyone have a pic)?
    Thanx,
    Todd
    Medford OR
    Dec 2016
    Mine just has tabs out but not the bent ones with the screw holes?
    Medford OR
    Quote Originally Posted by zakt View Post
    What's the part number on the ECU?
    Someone cut the screw holes off for some reason.
    Medford OR
    Yep... Can't imagine why someone would do that...
    Pretty easy to swap it onto a new base. Just find an old dead ECU from any year or trim 3S that you can cannibalize for parts.
    Since it's obviously been replaced... That ECU is a Fed spec 94-95 Turbo car. Is that the correct application for yours?
    Dec 2016
    yes my is a 95 VR4, 6sp (looks to be the right ECU) previous owner did a lot of stupid stuff..... now to fix it all
    I see a MD339760 for a core will this work to swap mine in??
    Medford OR
    yes, that will work, All you need is the base... your board and cover will bolt right on.
