got the center console out and the computer/ecu is just laying in the front, how is that mounted (anyone have a pic)?
Thanx,
Todd
Thanx,
Todd
Mine just has tabs out but not the bent ones with the screw holes?
Someone cut the screw holes off for some reason.
Yep... Can't imagine why someone would do that...
Pretty easy to swap it onto a new base. Just find an old dead ECU from any year or trim 3S that you can cannibalize for parts.
Since it's obviously been replaced... That ECU is a Fed spec 94-95 Turbo car. Is that the correct application for yours?
yes my is a 95 VR4, 6sp (looks to be the right ECU) previous owner did a lot of stupid stuff..... now to fix it all
I see a MD339760 for a core will this work to swap mine in??
