I believe Chris claimed 700-750hp before his mains lifted.
My oil pressure has always been on the good side. :P I don't know when my oil pump was replace it has been but I have always been at a good pressure level. As you guys know the lmi shits took a crap so yeah just seeing what turbos I want to get and have my car still be reliable as it always been to me.
hey gump, can you run anymore boost with 91 octance? or you just limiting to 16psi for another reason?
And the list goes on...
I'm running 93, but I wouldn't say I'm limited to this boost, I just have not tuned higher. I have finally got my tune completely ironed out, I ended up having to pull up to 3 degrees of timing in some places to have zero knock and I finally got it consistently setup for about 11.0:1 AFR.
I'm aiming for 18 or so until I start tuning with meth. At that point this old engine may say enough, I don't know, it still has good oil pressure and doesn't use oil.
The biggest obstacle to my tune turned out to be lift throttle knock I thought was happening during the pull. I was going by the scanmaster a lot of the time and started logging a ton and saw that at 50% throttle I had a bunch of knock. Fattening it up at that TPS range solved it. I love the 16 rows of TPS airflow correction the e-manage can do.
Because I saw no knock when pulling at WOT it was really inconsistently knocking at lower throttle amounts, especially when letting off after a pull.
Yeah, I had to pull 3 degrees at 4000 and 5500, but by pulling that 3 degrees I kept the ecu from pulling timing. Even at 5 counts of knock my ECU was pulling about 4 degrees of timing (when I had 2 pulled out). Pulling out one more final degree avoided that and I have 3 degress MORE actual timing than before.
Lesson learned, even low knock counts can kill timing and don't be afraid to pull a little where you need to.
You can run whatever you want; whether or not the engine stays together is the question. Up to about 500 HP, the determining factors will be the condition of the bottom end and the oil delivery system. Above 500 HP, the cast crankshaft becomes an issue. I have always said the cost of a total rebuild BEFORE it becomes necessary due to engine failure is cheap insurance. I would personally spend the money to rebuild the engine with an upgrade to a forged crankshaft now. Oh, BTW, "good" oil pressure isn't always a guarantee the oil delivery system is providing good lubrication. Indicated oil pressure can be affected by a restriction in the system, causing the gauge to read "good" while the actual delivery pressure/volume is not adequate. And, if you are relying on the stock oil pressure gauge, we all know how inaccurate they can be.
My point is this: rather than worry how much your engine can take before it blows up, spend the money on a bottom end that can take all the power you care to throw at it? Just my 1.5 cents worth.
More of a TQ issue. Right around 700AWTQ the girdle would push off the block.
I developed a 2 bolt girdle kit to help with this and made 747AWTQ without pushing the girdle.
And yes, my 2 bolt was oem forged crank, not cast. 3SX rods and Ross pistons, stock heads and cams.
747AWTQ 811AWHP.
My current build is 4 bolt and ran 835AWHP.
Anything under 650AWTQ or 700AWHP I would not hesitate running a 2 bolt with a forged crank.
-Chris
How hard is is to change the oil pump out? I have 180,000 on my vr4 and it might be stock just thinkin about putting in a new one to be on the safe side
93 vr4/87 Iroc-z
