Knock down the max rpm to just above where you will rev.
Then if you need more resolution at certain rpms you can monkey with it even further, but evenly spaced break points are likely okay.
Same for psi. If you have a 5 bar sensor but no plans to run more than 32 psi, make your max 35psi.
