Results 1 to 8 of 8
Thread: Where to get brake parts???
    Never finishes any verified
    Wake Forest, NC
    So I'm in the process of building my TT from ground up. I got my TT calipers and I need to find bolts to actually mount then to the hub. Besides 3SX where can I get a set of these?
    I am also missing one of the bolts that actually holds the two halfs of the caliper together! Thee are four bolts that hold the front part of the caliper to the back. I am missing one of those bolts. All local hardware stores don't carry anything that long. I can't even find the bolt in the manual or CAPS!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    XLR8TOR
    Las Vegas, NV
    Want the best that money can buy? Check out ARP. They are not cheap but they are the best.
    http://www.arp-bolts.com/
    You must have shitty hardware stores because mine had them. I had to grind the back ones a little though because they were a little long.
    Wake Forest, NC
    Yeah all of the ones I know of don't carry a large supply of metric hardware much less M12 x1.25 grade 8!
    Just buy them from 3sx then. They are sponsoring this board now.
    Raleigh, NC
    You must live in Raleigh. I found the same thing on my search to find some replacement hardware for my VR4.
    Chicago area.
    Ouch, small stores FTMFL.
    If you try 3sx and the others but they are no help, hell I would go to my local hardware store and grab a few for you if you are in that bad of a spot.
    Durham, NC
    Maybe you should check out all my "buckets o' bolts" when we meet up for the wheels. Got a ton, but not sure what exactly. And if you can find them in what I have, you can take them, no charge.
