Results 1 to 10 of 11
Thread: Lucas Injector Latency
    Gents,
    Time to install my Walbro 400 E85 Pump, Lucas 550CC Injecotrs, Hotwire Kit in order to prep for the S15 Billet Turbos I just ordered. The issue I'm having is I can't find the Injector Latency to plug into chrome. After the countless hours I have not succeeded. The only thing I have found is that apparently Lucas is just renamed from RC Engineering Injectors. Second question: What issues will I have if I can't find the exact injector latency?
    I've ran these injectors with the RC values. Works perfect.
    Thanks Greg! BTW I was reading, I know the Lucas Injectors and the pump i bought are compatible for E85 and I read that is all I need to run E85 is this true?
    You should be good.
    Jun 2011
    Sweden, Gothenburg
    Lucas is same as PTE right? Ive posted the exakt values for PTE 550cc on this forum. On mobile now so u have to find the post yourself
  6. The Following User Says Thank You to Ange For This Useful Post:
    My PTE 1200's are Lucas by all accounts..
  8. The Following User Says Thank You to KeithMac For This Useful Post:
  9. #7
    Jun 2011
    Sweden, Gothenburg
    alright well here they are if he couldn't find them
    ms@voltage:
    1.63ms@8.7v
    1.00ms@10.4v
    0.80ms@12.2v
    0.70ms@13.9v
    0.60ms@15.6v
    0.56ms@17.4v
    0.56ms@19.1v
    0.53ms@20.9v
  10. The Following User Says Thank You to Ange For This Useful Post:
  11. #8
    Guys thanks for all the help! Greatly Appreciate it.
  12. #9
    Does anyone know the correct latency settings for 1000cc Lucas 96lb injectors? I used the RC values but I feel like it's not correct due to rc's being 95lb
    10-1.17
    11-0.95
    12-0.80
    13-0.67
    14-0.56
    15-0.46 ??
  13. #10
    Quote Originally Posted by planeteclipse1221 View Post
    10-1.17
    11-0.95
    12-0.80
    13-0.67
    14-0.56
    15-0.46 ??
    really all you can do is start with something close and narrow in on it experimentally. Just highlight all the values and increment or decrement it the amount your idle trim is off. I like to start with the values in Merlins Ecuflash tuning guide (google it) PTE should be the same injector FYI. The only difference is evo scaling looks lower due to the way chrome is setup, you should start scaling near what your injectors are rated at, but a little conservative, like 950 in your case.
