Results 1 to 10 of 11
Thread: Low RPM low load knock
    Member
    Arvada, CO
    For a while know I have gotten the occasional CEL for knock while driving around at low load and RPMs. its typically around 2000RPM and near 0 vacuum. If I let off or apply more throttle the knock goes away. For a long time I was unable to get a datalog of it because it only ever seemed to happen when I was just out and about, without the laptop. Well today I was finally able to get a datalog of it happening and was hoping to get some ideas on what might be causing it. I have already pulled some timing in that area and it still knocks sometimes.
    https://drive.google.com/open?id=0B3...U1nX09NTHA0ZzA
    Member
    Arvada, CO
    I should add some details about my setup probably.
    stock block and heads
    stock intercoolers and piping
    DNP hard pre-turbo pipes
    TD04H-16T turbos
    Chrome
    Evo MAF
    DSM 450cc injectors
    solid front and rear mounts
    Poly side mounts.
    I lack color... verified
    Aug 1998
    That's quite common and is usually false knock.
    Member
    Arvada, CO
    Im assuming its something vibrating or resonating when the engine load and RPMs are just right then? likely due to the solid mounts? any way to keep the PCM from seeing that as knock or do I just have to live with it and change the throttle position when it occurs?
    Aug 1998
    Just have to live with it.
    Oct 2011
    Sundsvall, Sweden
    My car does the same thing and has done it for years. I wouldn't worry about it as Greg says.
    Member
    Arvada, CO
    Dang. I was hoping there was a way to play with the knock tables in Chrome so it doesnt see it as knock. If I have to live with it so be it, its not like its going to hurt anything, its just annoying.
    I get this too as well as partial throttle boost situations and it pulls timing so hard my car makes no power. I am ripping my hair out dealing with this and even considered going back to a 1g ecu just so I can drive my car normally again.
    August 2010
    Chicago
    no issues here Thank God
    34XXlbs..
