Results 1 to 10 of 12
Thread: Hot start problems after upgrades
    Sep 2014
    x
    So car run just fine before any of the upgrades listed below and now cold starts just fine but after running and sitting for awhile (30 mins or so) cranks for 15 sec or so before starting and runs supper lean for 30 to 40 sec before the o2 sensors start cycling and returns to normal. Going to start uninstalling stuff to find out what one is causing this unless this is a common thing with the upgrades and just have to deal with it.. Read on 3si about hot starts and some common suggestions there were to check the coolant temp sensor which mine is fine, possibly fuel vapor in the lines but have evoscan and tried cycling the fuel pump a couple of times before starting and get the same results. Like I said car ran just fine prior to the following upgrades. So im assuming one of these is the problem. Any suggestions?
    thanks
    Upgrade List
    dr 650 turbos
    apexi neo
    maft and 3.5" maf (zeroed out)
    rc 550 injectors
    new fuel pump hotwired
    VR-3747 :D Not Verified
    Dayton Ohio
    This is a super common problem, and I have no idea how to fix it. I have heard the same stories you have, but none of them seem to really fix the issue.
    Me and my friend with a VR4 have this issue. I usually just give it some gas (~1500 rpms) for a few seconds after a hot start and then it seems to be fine. I'll bet it's an easy fix but idk what it is.
    Sep 2014
    x
    Its embarassing starting this thing around people so i hope theres a fix and dont have to just deal with it.
    Well swapped out the gm maf and maft with the factory maf and no more hot starts so far. I'll keep the factory maf on for awhile and make sure it don't resurface. Seems most people zero out the maft and just use the neo to adjust everything. Am I missing something simple here? Everything else with the maft and gm maf works fine just the hot start problems.
    Does the GM MAF have IAT/barometric sensors in it like the stock MAF?
    Sent from my iPhone using Tapatalk
    Member
    Arvada, CO
    Even if they do Im pretty sure I read somewhere that the MAFt locks the IAT and baro at preset readings.
    Yeah, after posting I went and did some research and you're correct. Still seems fishy that switching back to the stock MAF eliminates the problem. If it were me, I'd do some logging of the air measurements on a hot start using the stock MAF and then the GM MAF and look for differences. Based on the thread I read, fuel pressure can also play a part.
    Dayton Ohio
    My friend (along with a lot of other people with this issue) all have stock MAF's.
    Not saying you didn't fix your issue, just saying that the problem is not the MAF when it comes to truly curing the hot start issue on these cars.
    Sep 2014
    x
    Well your right thought it was good but did it again with the stock maf. It must have something to do with changing the signal to the ecu because ive owned the car for like 15 years and has never done that before. O well I guess im stuck with it the way it is like everyone else but it sure is fun to drive now
    Maf-t (v2+) has a startup enrichment feature which may help you?.
    I run Maf-t in blowthrough with EMU and have slight lean issue on heatsoaked engine but it never fails to start, maybe due to injector correction vs aiflow correction?.
    Wrench Monkey Not Verified
    Rochester, NY
    There is a hot start enrichment factor in the ECU that you have to change when you upgrade injectors to avoid this problem. With a flash ecu that's easy. Not sure if you can do anything about it with your setup.
