So car run just fine before any of the upgrades listed below and now cold starts just fine but after running and sitting for awhile (30 mins or so) cranks for 15 sec or so before starting and runs supper lean for 30 to 40 sec before the o2 sensors start cycling and returns to normal. Going to start uninstalling stuff to find out what one is causing this unless this is a common thing with the upgrades and just have to deal with it.. Read on 3si about hot starts and some common suggestions there were to check the coolant temp sensor which mine is fine, possibly fuel vapor in the lines but have evoscan and tried cycling the fuel pump a couple of times before starting and get the same results. Like I said car ran just fine prior to the following upgrades. So im assuming one of these is the problem. Any suggestions?
thanks
Upgrade List
dr 650 turbos
apexi neo
maft and 3.5" maf (zeroed out)
rc 550 injectors
new fuel pump hotwired
