Meth injection? EGT's is pretty low.
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
Cool. Makes me jealous, no E-85 where I live. I've seen 1040C on 92 and 9b's
Haha nah, do not be! It has its pros and cons for sure; pump/race+meth is still a proven route if a viable option . Ideally, I would like to keep it under a grand when pushed the hardest. Tuning aside, his [exhaust] setup is pretty solid with a coated front GCTech manifold, DNP rear o2 housing, Stillen DP, and Tanabe Hyper Medallion Touring CBE.
Joining the hype...on this forum as well! lol
1991 Monza Red VR4- Weekend ride: Tanabe Super Medallion Hyper exhaust, 0.8 bar WGs, Turbosmart MBC (@1 bar), 3SX turbo pre-pipes, Straight pipe, Greddy Type RS BOV, Godspeed FMIC w/ PPE pipes, Stillin DP, HKS duel filters, RPS stage 2 clutch, 3sx SS clutch line, Custom oil catch can w/ braided lines, Krank vents, Ohhnoo's fuel loop, HW fuel pump, PC'd 2G brake swap w/3sx SS lines, Hawk pads, and Stop Tech rotors; Various deletes, PC'd/polished engine stuff, Koyo rad, Greddy coolant cap, DBest custom oil cap, Pit Road M front strut bar, PRM plug cover, PRM tailights, PRM CF Falcon hood and PRM shift knob, Morgan Motorsports splitter, 19x8.5 +27/19x9.5 +24 Volk GT-Cs wrapped Nitto NT555s, 99' bumper conversion, 99' sail panels, 2G side skirts, Retrofitted 5G Celica mirrors, Retro Spec side splitters, RS rain guards, and RS rear window visor, factory GTO light up visors, Custom fit Top Secret style diffuser for 350z, Robo mod w/halos, 3G rear garnish, Momo steering wheel, Tein Street Flex coilovers, 3SX control arms, Apexi turbo timer, Apexi mechanical boost gauge, Zoom Engineering Penta rear view mirror, Veilside navigators foot rest, Pioneer HU
I was able to put in some work today, so here are a few updates:
"Vacuum block is in play! I still have much to do underhood hehe."
The same BC setting resulted in a few more lbs:
"Making progress at 524AWHP//615AWTQ VD SAE (+25//30 U/C). IAT's are still ridiculous, so that will be my next focus. If underhood heat control does not yield enough, then we may consider upgrading to an ETS IC core. Next culprit would then be the turbos."
Preview: Billet 19T's @31psi on Pump-E85 and AEM EMS S2 <<
Lots o tq!
What's it look like ran out to 7k? Looks like hp/tq is dropping really fast. Big boost leak somewhere which could cause the high IATs along with hp drop?
Yeah, she is a torque monster right now and pulls well as-is. The current FB discussion with "mjannusch", Chris/NP, Tim of BM, and Jamison suspect that it is a wall in turbine flow. Tim confirmed for me/us that it is a standard MHI "HL" with no clip (not a 9-blade either).
I am still continuing with my current plans as 30+ over ambient and soaking afterward is not the beezneez lol.
-sent from my Galaxy S4
Link to discussion? Unless its private
Just throwing things out there, but I am not a huge fan of that coupler arrangement near the throttle body and I really don't like the tiny air filters. Its not scientific, but they look worse than the stock bubble. Maybe do a pull without the filters? If the turbos are seeing vacuum in their inlets its only going to drive AITs higher.
