Page 1 of 9 123 ... LastLast
Results 1 to 10 of 90
Thread: 19T + e85 too much for stock bottom?
    Jun 2011
    Sweden, Gothenburg
    seems like it
    SoSoCal verified
    Quote Originally Posted by Ange View Post
    seems like it
    the turbos were my old Phantoms, and the answer is yes
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    ^Yup!
    I already knew the gamble that I was taking after seeing Jeff's results with 19T's and meth back in 2010 on stock bottom.
    19T-L's 594AWHP/551AWTQ - Page 11 - 3000GT/Stealth International Message Center
  4. The Following User Says Thank You to bboyalan For This Useful Post:
  5. #4
    Jun 2011
    Sweden, Gothenburg
    Alright cool. Good luck with the rebuild!
    Sticking with 19t's or going bigger?
    BUS LENGTHS
    penn, PA
    Too much meth??
    I'm glad I didn't throw a rod through like that.
  8. #7
    Torque is a hell of a drug
    Low & Slow verified
    Fortson, GA
    Quote Originally Posted by Hard AttacK View Post
    Too much meth??
    Actually, it was too little methanol. I found leaks later that I never posted about. That is why it knocked and the knock bent the rod. The push on type fittings that all the injection places like to sell are freaking junk. I have converted the whole system to brass compression style fittings and no more leak issues. Prolonged 500+whp will eventually break things but that incident was because of the lack of octane.
    Jeff
  10. #9
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    OEM bearings are not up to a 600hp task for very long. When you bend a rod its because you had a misfire or you hydrolocked said cylinder. Window'd blocks/bent rods are typically user/mechanical error.
  11. #10
    Mix your Meth into the petrol then one less thing to worry about!.
  12. The Following User Says Thank You to KeithMac For This Useful Post:
