didnt you say your wideband is reading 12.9 at idle Jim?
I'm sorry Chris, I should have checked your formula more carefully. It is exactly the same as mine when you do the math!!
I do have 12.9 AFR at idle but that's another issue![]()
Just curious: how come you two don't use the wideband scaled option in chrome?
I thought I was
I have the sensor wired to pin 93 and I have the equation from post #1 programmed for the scaling for request BF.
What other way is there and why would I use it?
I also want this to work using the standalone tactrix 2.0 module with the SD card, and it DOES!!
I'm trying to use a gauge layout now when I use Evoscan for logging and found one that uses the External Wideband so I changed it to use Wideband Scaled but I don't get any readings on the gauge even though the logging works fine. Any light on that?
I was afraid of that... Who told you to edit the request formula for that request?
In chrome, the AFR scaling is done in the ROM, not in EVOScan. There's a few reasons why I did this but let's just say without getting into detail that it has to do with future versions of Chrome.
http://www.3sgto.org/tuning-engine-e...tml#post211632
All you do is setup the table and log the wideband request. Changing the formula will only cause it to spit out erroneous numbers. This maybe why you're seeing 12.6 AFR at idle. It may not necessarily be that the engine is running rich.
The correct formula for wideband scaled is x*.0627+7
To answer your question about the gauges, it doesn't work because that parameter is looking for a serial input not a MUT request. You have to make a new gauge for wideband scaled.
