Thread name is a misnomer - the scaling change is done in the Chrome ROM, NOT Evoscan
I'm using the UEGO 23-10 wideband which comes without a gauge to keep the sleeper look.
The AEM documentation states AFR = 2.375*V + 7.3125 and that 0.5V corresponds to 8.5 AFR and 4.5V corresponds to 18.0 AFR. These are for gaseline of course. If you are on E85 or some other fuel the AFR equation is different so check the AEM documentation.
Now what we have to do in Chrome 2 is open ECU Flash, load your current .bin file and go to the Sensor Scaling section.
Under WB Scaled in the Chrome 2 ROM I generated the values to correspond to the equation (2.375 * (255/x) + 7.3125). The table comes out to
Volts AFR
0 7.3
1 9.7
2 12.1
3 14.5
4 16.8
5 19.2
Flash these values into the ROM and then you are ready to test it with Evoscan.
In the Wideband Scaled request BF in Evoscan the scaling formula should be left as x * 0.0627 + 7. DO NOT CHANGE IT. This is where I initially screwed up.
With this I now have 14.5 - 14.7 AFR at idle![]()
