Results 1 to 10 of 18
Thread: Question Regarding Fuel Trims
    Ok, been reading all day. Trying to tune the low and mid fuel trims. So I do my first log and have a 12.5% on both front and rear mids trims. I have changed the MAF smoothness now by a total of +12% and it is still at 12.5%. The lowest I have seen is a 12.3%. The Lows are -10% rear and 2% front. I will be doing a vac check next weekend and Im going to check and see if I can find out what type of fuel injectors are on this bad boy. I was told they were stock, but I wasn't told about the car had a 1Piece CFDS and headers already installed. Any other ideas will be greatly appreciated for my trouble shooting purposes. Appreciate any help or advice.
    -Mike
    Oct 2010
    St Louis
    Mike,
    What year is the car?
    Does the car have the stock fuel system or does it have aftermarket parts?
    Does your car have an aftermarket fuel pressure regulator?
    How many miles are on the O2 sensors?
    Low Fuel Trims are the idle trims FYI.
    A bad or lazy O2 can cause many problems with fuel trims.
    Having an poorly adjusted FPR can cause problems.
    It is not uncommon to have large changes in the VE table if you have intake changes, such as intercooler, piping, MAF, or exhaust changes, such as headers.
    It is not uncommon to have some variance between front and rear, although -10 and +2 is a bit off . . .
    www.ClonedECU.com
    Get Chromed!
    1999 3000GT VR4
    Glacier Pearl White
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
    96 VR4 Spyder. 78K. The car has aftermarket FPR, Filter, fuel rail loop, and I'm almost positive it has stock injectors. I have full exhaust, dual core intake and rebuilt TB by april, VAC reduction. I bought the car before deployment and only been back for a month and half so I'm still learning about the car and unscrewing everything the prior owner had done. Thanks for the help.
    Sounds like you should get the car running good on the stock ECU before trying the flash ECU.
    With the EVO MAF wired in that is not really an option. But prior to switching the car to the flash ecu it was running solid. But I may resort to this if after trouble shooting I may need to cut in and rewire the Stock MAF.
    Member
    Arvada, CO
    If you need to put the stock MAF back in I have a connector that fits the EVO MAF. It will allow you to make an adapter harness using the stock 3S connector so you dont have to cut the EVO connector back off.
    Quote Originally Posted by BlackSpyderVR4 View Post
    A bad MAF would cause the issues you're experiencing.
    Well I went to Autozone to get the CEL checked. I was throwing 16 codes. I will have to go recheck the tune. I was throwing every code you would get from the VAC reduction (Wastegate, EGR, ETC) and then there were some O2 Heater and the trim codes were being thrown. I could have sworn I set up the ECU properly so It wouldn't throw the codes. The guy was useless and basically I asked to see the CEL Reader and read the codes myself. I will be going back tomorrow see if I get someone who knows what there doing or get that EVOSCAN 2.6 working so I can read my own codes. Also I used my compression check and I tried to pump it up with a tire pump and it just wouldn't build pressure. So I will be taking it to the DIY shop and use there air hoses to fill it up with air and find the leaks. I appreciate the help Gents and will keep you guys updates. If any more a Ideas come to your head please let me know.
    JNS Engineering verified
    San Jose, CA
    ..... get that EVOSCAN 2.6 working so I can read my own codes.....
    If it's a stock 96 ECU it's not going to happen. Evoscan 2.6 won't connect reliably with the stock 96 ECU. I've personally verified v2.5 and v2.7 work with teh 96, not sure about v2.9
    So I found a possible contributing factor. My rear turbo hot pipe going to intercooler wasn't even bolted down. I don't know how the car was Boosting so easy.
