Hopefully this will help some unlucky soul in the future as well as source community knowledge / suggestions.
The Basics:
91tt bpu,
Brett's ECU
Antero's harness (i assembled)
Wintel/Win7 (6.1.7601 Service Pack 1 Build 7601)
Evoscan (any version)
EcuFlash (1.44.3721)
Tactrix openport 2.0 (firmware 1.12.3688)
The Issues:
1. EcuFlash will communicate (and write) to the ecu but EvoScan version 2.6, 2.7 or 2.9 will not initiate communication.
I receive the following:
Info: OpenPort 2.0 Found.
Info: OpenPort Firmware v1.12.368
Info: Battery 12.068V
Info: Initialize Vehicle ECU...
Info: Initializing At 5 baud...
Info: Timer: 2480.006ms
Info: Initialization Complete...
Info: Waiting for INIT Response...
Error: J2534 Read Error - 16
Info: Datalogger Ended.
EcuFlash on the other hand reads and writes:
174625.530 EcuFlash Version 1.44.3721
174625.530 OS Version Windows 7
174625.530 Qt Version 4.8.0
174625.541 63 memory models read.
174625.541 scanning for metadata models in f/ecu/OpenECU/EcuFlash/rommetadata
174625.684 612 ROM metadata models scanned.
174625.684 checksum module subarudbw loaded.
174625.684 checksum module mitsucan loaded.
174625.684 checksum module mitsuh8 loaded.
174625.684 patch module Subaru CAN Enhanced RAM Parameter Logging loaded.
174625.684 patch module Mitsu CAN RAM Parameter Logging loaded.
174625.686 flashing tool wrx02 loaded.
174625.688 flashing tool wrx04 loaded.
174625.690 flashing tool sti04 loaded.
174625.692 flashing tool sti05 loaded.
174625.692 flashing tool mitsukernel loaded.
174625.692 flashing tool mitsukernelocp loaded.
174625.692 flashing tool mitsubootloader loaded.
174625.692 flashing tool shbootmode loaded.
174625.693 flashing tool shaudmode loaded.
174625.695 flashing tool subarucan loaded.
174625.697 flashing tool subarucand loaded.
174625.699 flashing tool mitsucan loaded.
174625.718 J2534 API Version 04.04
174625.718 J2534 DLL Version 1.00.3721 Jan 9 2013 172459
174625.718 Device Firmware Version 1.12.3688
174625.718 Device Serial Number TA$1ZuBJ
174625.719 interface close
174625.750 J2534 API Version 04.04
174625.750 J2534 DLL Version 1.00.3721 Jan 9 2013 172459
174625.750 Device Firmware Version 1.12.3688
174625.750 Device Serial Number TA$1ZuBJ
174625.750 interface close
174625.760 J2534 API Version 04.04
174625.760 J2534 DLL Version 1.00.3721 Jan 9 2013 172459
174625.760 Device Firmware Version 1.12.3688
174625.760 Device Serial Number TA$1ZuBJ
174625.760 interface close
174628.988 131072 byte image read.
174628.988 using metadata XML ID 23862006 from file f/ecu/OpenECU/EcuFlash/rommetadata/mitsubishi/23862006.xml
174644.268 J2534 API Version 04.04
174644.268 J2534 DLL Version 1.00.3721 Jan 9 2013 172459
174644.268 Device Firmware Version 1.12.3688
174644.268 Device Serial Number TA$1ZuBJ
174649.720 sending init sequence 2
174649.730 got 0x11 response
174649.730 sending init sequence 3
174650.090 entering bootloader
174650.090 sending kernel size (2029)
174650.100 sending kernel load address (0x0000F000)
174650.110 uploading kernel
174650.440 verifying kernel checksum response
174650.440 kernel valid
174650.640 kernel get version
174650.650 kernel version is OpenEcu Mitsubishi H8/539F Kernel V1.07
174650.650 reading kernel comm buffer size
174650.680 comm buffer size set to 256
174650.680 reading kernel flash buffer size
174650.690 flash buffer size set to 1024
174650.713 -- flashing image to ECU memory --
174651.122 -- comparing ECU flash memory pages to image file --
174651.122 seg start len ecu CRC32 img CRC32 same?
174651.272 LB7 00010000 00003000 18023FFE 1EFDA5D6 NO
174651.292 SB0 00013000 00000200 D90A49D9 D90A49D9 YES
174651.312 SB1 00013200 00000200 614E4403 614E4403 YES
174651.322 SB2 00013400 00000200 9C5C2520 9C5C2520 YES
174651.342 SB3 00013600 00000200 9D0A5827 9D0A5827 YES
174651.352 SB4 00013800 00000200 529496AA 529496AA YES
174651.372 SB5 00013A00 00000200 AB1E2EDA AB1E2EDA YES
174651.382 SB6 00013C00 00000200 01D43F34 01D43F34 YES
174651.402 SB7 00013E00 00000200 BD7BC39F BD7BC39F YES
174651.602 LB6 00014000 00004000 570329C0 570329C0 YES
174651.802 LB5 00018000 00004000 5363B41F 5363B41F YES
174651.992 LB4 0001C000 00004000 D4CD69CA D4CD69CA YES
174652.192 LB3 00020000 00004000 5E12815E 5E12815E YES
174652.392 LB2 00024000 00004000 968D0FC7 968D0FC7 YES
174652.592 LB1 00028000 00004000 BFC27FD9 BFC27FD9 YES
174652.792 LB0 0002C000 00004000 8F3E818E 8F3E818E YES
174652.792 kernel flash enable
174652.822 kernel blank flash page addr 00010000
174653.574 erased in 10 pulse(s)
174653.574 kernel write flash buffer addr 00010000 len 00000100
174653.625 kernel write flash buffer addr 00010100 len 00000100
174653.666 kernel write flash buffer addr 00010200 len 00000100
174653.716 kernel write flash buffer addr 00010300 len 00000100
174653.766 kernel commit flash addr 00010000 len 00000400 crc32 6330f141
174653.836 written in 4 pulse(s)
174653.836 kernel write flash buffer addr 00010800 len 00000100
174653.887 kernel write flash buffer addr 00010900 len 00000100
174653.928 kernel write flash buffer addr 00010A00 len 00000100
174653.978 kernel write flash buffer addr 00010B00 len 00000100
174654.034 kernel commit flash addr 00010800 len 00000400 crc32 e51fa8bb
174654.100 written in 4 pulse(s)
174654.100 kernel write flash buffer addr 00010C00 len 00000100
174654.150 kernel write flash buffer addr 00010D00 len 00000100
174654.200 kernel write flash buffer addr 00010E00 len 00000100
174654.250 kernel write flash buffer addr 00010F00 len 00000100
174654.300 kernel commit flash addr 00010C00 len 00000400 crc32 61b412be
174654.370 written in 4 pulse(s)
174654.370 kernel write flash buffer addr 00011000 len 00000100
174654.426 kernel write flash buffer addr 00011100 len 00000100
174654.472 kernel write flash buffer addr 00011200 len 00000100
174654.522 kernel write flash buffer addr 00011300 len 00000100
174654.572 kernel commit flash addr 00011000 len 00000400 crc32 05211dd0
174654.642 written in 4 pulse(s)
174654.642 kernel write flash buffer addr 00011400 len 00000100
174654.695 kernel write flash buffer addr 00011500 len 00000100
174654.744 kernel write flash buffer addr 00011600 len 00000100
174654.784 kernel write flash buffer addr 00011700 len 00000100
174654.834 kernel commit flash addr 00011400 len 00000400 crc32 57012e2e
174654.894 written in 4 pulse(s)
174654.894 kernel write flash buffer addr 00011800 len 00000100
174654.944 kernel write flash buffer addr 00011900 len 00000100
174654.996 kernel write flash buffer addr 00011A00 len 00000100
174655.046 kernel write flash buffer addr 00011B00 len 00000100
174655.096 kernel commit flash addr 00011800 len 00000400 crc32 2692d34d
174655.166 written in 3 pulse(s)
174655.166 kernel write flash buffer addr 00011C00 len 00000100
174655.216 kernel write flash buffer addr 00011D00 len 00000100
174655.258 kernel write flash buffer addr 00011E00 len 00000100
174655.308 kernel write flash buffer addr 00011F00 len 00000100
174655.358 kernel commit flash addr 00011C00 len 00000400 crc32 d1425302
