Page 544 of 892 FirstFirst ... 44444494534542543544545546554594644 ... LastLast
Results 5,431 to 5,440 of 8916
  1. #5431
    I used VHT spray paint and an electric sander to do mine, IIRC around 80 grit.
    Edit: Red caliper is red.
  2. #5432
    JNS Engineering verified
    San Jose, CA
    Powder coat + 300 grit and re-plated bolts here
  3. #5433
    Put a new slave cylinder in the SL, and lubed and reassembled the TT's freshly painted shifter.
  4. #5434
    Finally got new tires on the car today. Also finally got some miles on the car after the build. Hit about 100 miles. Everything is still good! What I am extremely happy about is my ac still blows ice cold.
    Also been soldering all the sensors to the pro efi main harness.
    Sent from my SPH-L720 using Tapatalk 2
    Black 1994 Mitsubishi 3000GT VR-4
    Billet DR650s, PRO efi 128 ecu w/ flex fuel, 52mm CAN gauge, FIC 1100CC injectors, Ported heads, Parker SS Fuel lines, Walbro 416lph e85 fuel pump, Maximal solid motor mounts, Spec stage IV clutch, Pampena bellhousing brace, Tail BOV, MSD wires, Enkei RZ-5 w/ Michelin Pilot Super Sports, Skillard front splitter
  5. #5435
    Sep 2012
    Decatur, TN
    Looked at it longingly.
    Eventually I'll get some money in and can wrap up this rebuild.
  6. #5436
    Started dyeing the carpet today. Combining a couple of methods I found online. I'll post results on my R/T restoration thread, in about 2 weeks, when its done.
  7. #5437
    I don't bite
    Southern IN
    Drove 8hrs each way to Topeka, KS to say "hi" to turbosincebirth....and buy a 5sp off of him.
  8. #5438
    Oct 2011
    Sundsvall, Sweden
    Reminds me of when I drove from Sweden to Norway last summer to buy a reinforced and rebuilt 6-speed from Taz.
  9. #5439
    One fix at a time verified
    Kansas
    Good to meet you Eric. Maybe next time we cross paths I'll have my car running and can take you for a spin.
  10. #5440
    Re-did the BOV from open atmo to recirculating so the engine doesn't bog and stall when revving up and letting off. RPMs drop smoothly and no more bogging. Idle tuned halfway decent now with the chromed ecu.
