Page 444 of 892 FirstFirst ... 344394434442443444445446454494544 ... LastLast
Results 4,431 to 4,440 of 8916
  1. #4431
    // Off the beaten path \\ Not Verified
    Cleaned and plastidiped the peeling, rusty rear window trim. Its still wet in the pics, so it will look more uniform once it dries. I'll probably redip the roof this weekend along with the plastics behind the sails. The roof was dipped ~2years ago.
    Stance Game Michael Myers
    19t RT/TT
    04 e60
    @Get_Like_M1ke
  2. #4432
    94 3500gt vr2? verified
    NC
    much better. good trick a lot of people are doing. aside from things like this, i'm tired of hearing about plastidip, lol
  3. #4433
    Yea, it's awesome stuff. Easy prep, dries fast, doesn't streak, and peels right off anything you don't want it on. I may end up doing my whole car flat white.
  4. #4434
    RTBOOST verified
    Florence, Wisconsin
    Quote Originally Posted by boosted3s View Post
    I have my old one of these if you'd want it for cheap. I only replaced it because I'm very picky & one of the sides had some of the seal pulling away...LMK if you'd be interested.
    Sent from the garage
  5. #4435
    Quote Originally Posted by Street_Chally73 View Post
    Appreciate the offer, but this works fine.
  6. #4436
    May 2012
    Central Fl
    Finally got some Megan Racing coilovers for my SL! Also replaced my cv axle with a brand new one from advance that ended up being thicker than my original? I didn't expect that. Super impressed with these coilovers so far though, huge improvement!
    1993 3000GT SL
    Mods: 95 front end, Robomodded Glass Headlights, VIS CF hood, Megan Racing Coilovers, relocated battery, short ram intake, VR4 Plenum, OBX LSD, OBX longtube headers, test pipe, 3SX underdrive crank pulley, Fidanza 9lb flywheel, Spec stage 3 clutch, solid lower engine mounts, 80a poly filled upper/trans mount, poly front sway bar bushings, Momo steering wheel, 3rd gen lifters, Konig 18" wheels, 4300k HIDs, gutted trunk, AC delete, PS delete, Cruise Control delete, ABS delete, SRS delete.. Plus other random stuff.
  7. #4437
    NC
    looks like the new axle doesn't taper down
    install the coilovers yet? if so, how do you like them?
  8. #4438
    Jun 2011
    Sweden, Gothenburg
    gutted rear precat.
    metal shavings raining in my eyes and face for 3 hours straight. yay
  9. #4439
    May 2012
    Central Fl
    Yeah it doesn't taper down at all, I'm guessing that would make it stronger? As far as the coilovers, I've thrown them through some tight corners, on ramps, taken them down some sub par roads, and I've had them up to about 140.. I'm really impressed with them, the car just feels amazingly stable. Oddly the biggest difference they made was that it's much easier to turn at low speeds now, I run no power steering with a manual converted steering rack and I can back out of my driveway with one hand now lol. I think my strut mounts were way overdue to be changed.
    Sent from my Galaxy Nexus using Tapatalk 2
  10. #4440
    STL, MO
    Quote Originally Posted by Ange View Post
    gutted rear precat.
    I don't understand this? I did it in about 50 minutes and that includes removing the down pipe .... Three holes in a triangle formation with a standard drill bit. Then used a flat style bit thingy and just used the holes as the entry point. ( that's what she said)
    1991 Stealth RT/TT
