Page 9 of 55 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 544
Thread: Tuning my DR750s on Chrome
  1. #81
    hahaha, this thread made me wonder how my loose, tired engine had never spun a bearing. Interesting hypothesis and you see the same trend with Trevor's E16G's. Those DR750's are really producing insane amounts of low end torque (TT Eric's DR750 TQ curve is hilarious). Good luck with the rebuild!
    FYI... I know Toni hasn't fixed it yet on his dyno plotting tool, but the graphing for TT Eric's TQ curve is WRONG. It's shifted 500 rpm over to the left compared to where it SHOULD be based on his actual dyno graph plot. Toni has mentioned he'd fix this, but, he hasn't had time yet. So, that's why his tq numbers look hilarious, because it's.. wrong, :P
    Best in Show - NG07
    2010 - 6G74/3.5L E16Gs - 688awhp/679awtq (Race+Meth)
    2011 - 6G74/3.5L 68HTAs - 740awhp/762awtq (Race+Meth)
    2013 - 6G74/3.5L MTC Stage4 - 908awhp/832awtq (Race+Meth) <--- Tuned by Ray Pampena
  2. The Following 2 Users Say Thank You to JRink For This Useful Post:
  3. #82
    VR-3747 :D Not Verified
    Dayton Ohio
    I'd be a betting man you bent a rod. The bearings probation went after the rod, not before.
    Jeff aka kywhitelightning had 19t HL's on a stock block vr4 with lots of meth and he bent one into a nice crescent moon. I would not at all be surprised if you did the same. And after you throw an engine off balance like that, you can't blame the bearings for not holding up.
  4. #83
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    On the engines I've seen fail with a bent rod... The rods folded because a cylinder filled with liquid. When we flooded a cylinder and the Otto cycle tried to compress the liquid and couldn't the rods bent. On one occasion the rods were strong so instead of bending we blew a a hole thru the block.
    I'm somewhat skeptical that 500 foot pounds of torque is the bending threshold for stock rods. I'm pretty sure that Matt Monet put down 600 to the wheels on a stock motor with DR750's and had no problems. There so many variables involved.
  5. #84
    Quote Originally Posted by JRink View Post
    Yup, sorry about that. I still haven't gotten around to fixing it. If you notice when you plot the TQ and HP lines they don't cross at 5252.
  6. #85
    Time will tell, I wouldn't be shocked to see a bent rod. It'll probably be about 10 days before I get this engine on the stand, this week is kinda shot.
    Just pulling off what I can in my spare time:
  7. #86
  8. #87
    I've seen bent stock 3S rods. I think one was with Phantoms. There's a fine line between a straight, bent, and broken 3S rod......it's easy to jump straight to windowing the block. Most people blow the pistons first from det though.
  9. #88
    Interesting, what is "lots of meth"?
  10. #89
    Dayton Ohio
    I don't know how much he was running bill. When I talked consistently to him, I knew about half as much as I do now. I know he told me it was quite a bit though.
    Jfast, yeah there are a lot of variables! Understatement of the thread haha! The fluid filled cylinder makes perfect sense, but Chris is not a Joe Schmo... I don't think that was his issue. I should really dig through emails and find pics of Jeff's rod... Anything north of 500 torque and you are in potential rod bending territory (from what I have seen) on a 3s. He has a dyno of hitting almost 600 horsepower, but I have seen other guys run on the same dyno and the numbers were quite inflated (trap speed proven). Jeff's car WAS quite fast though, no doubt.
  11. #90
    One fix at a time verified
    Kansas
    Quote Originally Posted by Autochef View Post
    Sorry to see this man, but with your knowledge and experience you'll be up and running in no time.
    If perhaps your oil was diluted with fuel, how do you gauge this? by smell? I have always had a habit of smelling my oil(on any car) and they always have a scent of fuel.
    Smell is the easiest indicator. I would notice tuning if I was running rich in the 10s and it started diluting my oil that at hot idle my oil pressure dropped 2-3 psi. Double checking the odor of the oil and also the viscosity of the oil you could tell there was fuel in it.
