Results 1 to 10 of 26
Thread: Rotating assembly component weight thread! Clutches, flywheels, pistons, rods, etc...
    Banned J. Fast's Avatar
    Lets build a database for this stuff and locate it all in one place... Please post up your individual component weights for clutches/pressure plates, flywheels, pistons, wrist pins, crankshafts, crank pulleys, clutch/crankshaft/crank dampener bolts... basically anything/everything attached to the crankshaft (including your crankshaft). Please make sure to note your manufacture specific piston diameter and compression ratings.
    I will do my best to update the thread and create a table for everything that's out there.
    Description Crankshafts Wrist Pins Pistons Rods Rod Bolts Clutch/PP Clutch Bolts Crank Pulley Flywheel Flywheel Bolts
    AASCO Chromoly V1 5263.8g
    AASCO Slide Bolt 131.5g
    Tilton OT-2 5443.1g
    Clutch Master V-Drive 6350.3
    Clutch Master Twin-Disc Allen 136.1g
    Ross 92mm 8.5:1 376.3g
    Wiseco 92.5mm 8.3:1 356.5g
    Mahle 92.5mm 9.0:1 335.8g
    Fidanza Aluminum Flywheel TT 4762.7g
    3sx Crank Pulley 771.1g
    Flywheel N/A 8323.4g
    Flywheel TT 9094.5g
    N/A OEM Clutch / PP 5579.2g
    TT OEM Clutch / PP 8164.7g
    1G Crank Pulley 2812.3g
    2G Crank Pulley 2903.0g
    6G74 Crank (Forged) 19731.3g
    Unorthodox Crank Pulley
    V1
    680.4g
    Unorthodx Crank Pulley V2 616.9g
    ARP 2000 Rod Bolt 54.4g
    ARP Aermet Rod Bolt 56.6g
    Carrillo Pro-H Rods 543g
    BC Sportsman 532g
    BC 6148 Billet Rods 530g
    3sx Rods 544.3g
    Crower Rod Bolt 57.6g
    Crower Rod 513.9g
    Pauter Rod Bolt 48.2g
    Pauter Rod 536.8g
    6G74 Pauter Rods 581.8g
    Wiseco 92mm 8:1CR 347g
    Venolia 92.5mm 8.2:1CR 377g
    Wossner 92mm 9.0:1 CR 368g
    CP Pistons 92mm
    8.5:1
    390g
    Fidanza TT Fllywheel: 10.5 lbs
    3SX Stock Sized Pulley 1.7 lbs
    Didn't get the weight of my clutch/pp..
    Edit: If we're doing G's (Respectively)
    4762.72g
    771.11g
    Ann Arbor, MI
    John Monnin started a list of 3/S component weights here a while ago:
    Monnin Engineering at wrenchjockey.com
    http://www.wrenchjockey.com/Webpages/Weights.xls
    4762.72g
    771.11g
    Is that a 1G or 2G crank pulley?
    IIRC they don't give a different number for the 91 or 92+ models.
    you cant get too hung up on the weights though.. i can make my engine parts as light as i want. its a balance act between material, weight and strength. i could definitely make my pistons and rods the lightest on the market by far but i wouldnt be able to sleep at night lol. it took me a few years to come up with parts that dont show bushing damage, bean stress, skirt distortion, ringland flex and pin boss flex while keeping a thick deck that doesnt distort. my point is, id hate to see people chase after the ligtest stuff.. then have inferior parts
    also, flywheels and dampers.. the heavier the better on those
    Quote Originally Posted by Ray Pampena View Post
    Yes, but not everyone has the same goals. There are some people who would rather have a lighter piston ect that is stockish strength. Personally I think the people who are either building a light engine or a heavy engine should know what they are looking for, so having the information available is helpful. No such thing as too much information.
    I'd really like a sub 8 lb flywheel and a 5.5" diameter clutch.
    Yes but isnt the goal to make HP?? High hp engines require the things I said in my post. If you are building a low hp engine.. what is the purpose of doing the light weight parts? To free up HP? Thats where it starts to not make sense to me
    Man vs 3/S verified
    Kingston, WA
    Some guys dont want a 500 hp engine.
